bx24 leak at hyd. manifold
   / bx24 leak at hyd. manifold #1
jondog
NEPA
BX25
Hey,been a long time creeper and found much needed info.After this winter heavy snow fall I parked her in the shop and found a drip,later found to be where the down pressure line goes into the manifold.Got to the 26mm nut and found not enough room to lift it out.Do I need to remove the entire line to replace the O ring?,if so it is way tight to get onto the nut between the loader and frame.Remove the battery?Any help guys...thanks..gotta get her online asap.
ok ...more research,cutting a hole in the bottom of the battery box?For an O ring swap,no other takers on this?How about the order numbers for the rings as I will order or pick up before tearing into it
   / bx24 leak at hyd. manifold #3
Sounds like a lot of trouble. Is it a nut ... or bolt head. Was/is it tight. I am not familiar. Do you know theres an oring seal or could it be a copper washer? In any case may be able to stop the seep/leak in place by use of Loctite wicking compound. It will creep into a tight crevice and set up. The leak path is then blocked. You can remove the bolt later if its ever necessary.
larry
Thanks for responding Larry, yes it does sound like a lot of work and I did put some Loctite in there and it seem to stop for now however it is a rubber O-ring I would like to repair it properly and I do appreciate your response thank you
   / bx24 leak at hyd. manifold #5
Are you positive it just didn't need to be retightened? If it's a bad O-ring I can't see Loctite sealing it.
   / bx24 leak at hyd. manifold #6
Wicking Loctite would seal the head of the bolt to its seat, effectively forming a seal beyond the oring.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2017-2023 Ford 4x4 Super Duty Pickup Bed (A49461)
2017-2023 Ford 4x4...
2016 MACK TITAN TD713 (A51219)
2016 MACK TITAN...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
