Tom_H
Veteran Member
BotaBigot said:For me on asphalt, a little less on the FEL, more on the BH...but on average, 10's a good number. I'm not even close on the MMM yet, but I've only had the BX since last June...I need more OJT...
I rotate the gauge wheels 90 degrees and re-pin them, raise the front end with the FEL, and the MMM rolls right out to the side. Now...we won't talk about reconnecting the U-joint![]()
Just2quickz28 said:without the concrete floor to build a dolly for the MMM it can be a total pain in the arse to put on and take off. I am really debating on just changing the guard wheels to casters.
The paved floor makes so much difference. Not trying to be critical of anyone here, but if one uses the FEL to raise the tractor for MMM attachment, then removes the FEL, mows, reattaches the FEL, then removes the MMM, that requires a considerable amount of time and work.
I have discovered that the dolly makes it so fast. In order to have enough clearance, the plywood needed to be thin; I used half-inch (or a hair less). The smallest swivel casters I could find were 2". The plywood was cut to match the exact profile of the bottom of the MMM skirt. Sixteen casters around the perimeter helps distribute the weight.
The MMM originally sagged just enough that the 3 spindle bolts beneath the blade centers rested on the plywood. This prevented me from being able to rotate the female PTO coupling when trying to reattach. This was solved by cutting small circular holes in the plywood beneath the bolts. The inner surface of the blades still rested on the plywood slightly. I noticed that the outer side edges of the skirt were not making contact with the deck surface, while the front and back were. I used some left over scraps of metal shelving standard (these are the metal strips that brackets are inserted into for shelf supports) as shims to go under those left and right sides. This lifted the sides of the MMM carcas ever so slightly, taking the pressue off the blades. That allowed the blades to pivot, and the receiver end of the PTO attachment to rotate. I used wood screws to attach the scraps of standard. Small wood trim strips would have worked as well. The front and back edges of the MMM skirt still make contact with the plywood.
The dolly leaves just enough clearance for the MMM to roll beneath the tractor (swivel casters make course adjustments far easier than when rolling with the anti-scalp wheels turned sideways). I still have to navigate slightly to avoid contact by the spring stems in a couple of places. This allows the anti-scalp wheels to always stay in the same position, though that position is slightly higher than I previously used them while cutting. I have found, however, that there has been no negative effect on the cut of the lawn.
My first season re-attaching the PTO coupling was frustrating. For me, it seems that delicate finesse accomplishes much more than brute force. Firstly, I angle the MMM on the dolly so that it is pushed a bit forward on the left side of the tractor. Laying on my left side, I can then get one arm on the receiver with enough room to maneuver it to the PTO shaft. I find that when it seems not to want to couple, I have success by lessening the amount of force and pressure I am using rather than increasing it. Having generous lube on the shaft and recepticle is helpful. I pull the locking ring back and let it lock in its retracted position. Using the very slightest amount of forward pressure, while simultaneously tilting/cantering slightly in every direction, while also slightly rotating the receiver back and forth, I find that the receiver usually slips over the shaft in less than 5 seconds. If it does not go, that almost always means I am forcing it too hard. When I push the receiver to the fully docked position, the slip link in the drive shaft does extend, but stops just short of coming apart. The dolly can now be alligned with the lift arm pins. The arms are dropped most of the way, final allignment made, then they are dropped fully. With the locking pins retracted but not locked back, the dolly can be wiggled as needed for the pins to slip through the holes. Three minutes on and off has become fairly consistant, but I've had my BX since Sept. of 2000. Experience has made a difference. I can't say whether frictional wear has broken in the shaft and receiver any and whether that has made coupling any easier.
