BX24 & Speeco PHD - my experience
   / BX24 & Speeco PHD - my experience #1
DaveVales
Buckley, WA
BX24 7/1/06; Cub Cadet 3225 5/98
Like many of you SCUT owners I wanted a post hole digger for my tractor and found the dealer's suggestion of Land Pride PD10 with 30" bit a tad high priced ($930 w/ 9" bit) for my modest needs of about 100 holes. The other PHD available locally was a TSC store affiliate who had a Speeco Model 100 with a 9" bit at $460. Would it fit was my conundrum. It had 4 holes on the boom compared to the normal 3 so maybe, just maybe it would fit given that others have modified the boom by driling another hole. I cannot find specs or discussions for the Speeco Model 100 Field Master anywhere so I think I am the guinea pig here.
I took the plunge and here is what I have to report. I have learned so much from people on this site I simply want to contribute to helping others.
Unmodified the yoke would fit into boom hole 3 (next closest to tractor) but the top of the boom would bump into the bracket above the top link. The 3 pt links were only about 1/2 way up. Height from the gear box to ground was 34" so a 30" auger may fit, but you would have to be careful not to bring the boom up too high or damage your tractor! My TSC does not carry a 30" bit so...
I decided that if I ground out the top part of the boom above the top link swivel (interesting design - holes for Cat 1 & Cat 2) I could get more height, not bind with the metal on the tractor, and possibly use hole 4 closest to the tractor.
So grind away I did, taking about 3/4" off the metal. I hope the attached picture is self-explanatory of how the grinding was done. Does this compromise strength and safety? I do not know. Now I have 56" height and with a 46" auger, I have 10" ground clearance.
***IF I bring the 3 pt all the way up I can still tighten up against the tractor and cause problems, so I can take more metal off and risk losing boom strength, or I can be careful and not raise the phd all the way up. I am hoping 10" will be enough ground clearance to do the hole digging work and that I can be careful. If not, more grinding.
I have not dug any holes yet - too many other attachments to play with on my 24 hour old tractor with 6 hours on the meter.
Hope this helps those of you who might be faced with this particular Speeco and SCUT tractor models.
   / BX24 & Speeco PHD - my experience #2
That looks like a good fix and I don't think you have lost much strenth. I would keep grining so I wouldn't have to worry about hitting anything and If you're worried you could weld a plate to the bottom.
   / BX24 & Speeco PHD - my experience #3
I've been wondering about a PHD for my BX as well. Thanks for taking the plunge. For strentgh though I would probably weld a couple of plates on either side. Then you could probably grind out a little mor material to increase your ground clearance.
ben
   / BX24 & Speeco PHD - my experience #4
Nice job,
Note: watch out, not to pinch that hydraulic line....
Bird
   / BX24 & Speeco PHD - my experience #5
I made the same mod to mine. I just finished 40 holes without any problems than the hard clay.
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
2014 International Maxxforce DT (A53317)
2014 International...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55314)
BOSS MT 660 Fuel...
2014 COMPTANK ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK ACID...
