BX25 MAX RPM
   / BX25 MAX RPM #11
I think the Owner's Manual says full throttle for mowing. The engines have a governor, so can't overspeed.
   / BX25 MAX RPM #13
All these engines are governed for 'high idle speed' which is the max rpm under no load and then 'governed max load speed' which is the speed at which the governor will go to wide open to maintain rpm. Max load speed is usually 2-300 rpm lower than max high idle speed. Unless you have a malfunctioning govenor or have messed with the high idle adjustment there is no worry about over speeding the engine. But as other have said use as much throttle as needed to do the job.
   / BX25 MAX RPM #14
I run my BX around 1800-2000 RPM for "regular" use such as pushing snow etc. When I need to go down the road in high gear, I'll push it up to 3000.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
Ingersoll Rand TS5 80 Gallon Air Compressor (A51573)
Ingersoll Rand TS5...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
