bx2660 and post hole digger
   / bx2660 and post hole digger #41
A Quick Hitch for $80 from HF extends your 3ph backward about 4". This extra space lets you use light duty full CAT 1 sized implements more readily on the BXs.
larry
thats good info on the q/a..just curious do you have that setup?
   / bx2660 and post hole digger #43
Yes, - - it will let me use a 7' sickle bar to cut around the lake. The mower sets too close to the tractor otherwise. Unfortunately the QA doesnt work well if you need to tilt the implement to the side. It stays on the BX1500 with a drawbar in it mostly. I do a lot of towing but not a lot of 3pt implement work with the BX.
larry
   / bx2660 and post hole digger #44
I have a BX24 and am looking at the Landpride PD15 for it, do you think there would be any problem using a 12" auger bit.
I know I'm sure I could put a 12" on mine and run it as deep as I could. Plenty of power.
2009 Lee-Boy 8510HD Conveyer Feed paver (A53472)
2009 Lee-Boy...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
