BX2660 MMM vibration
   / BX2660 MMM vibration #11
The three cylinder mule is bolted directly to the frame and it has no isolation with motor mounts(none there period), and the tires simply add to the resonance, plus the mower adds even more.
leonz
For this tractor, and the BX series, the motor is not mounted directly to the frame and is on rubber mounts
   / BX2660 MMM vibration #12
If the MMM isn't engaged the tractor does NOT shake at all at any rpm.
The dealer said it isn't anything to worry about just mow at 3000rpm. I'm fine doing that. However, because the tractor is brand new and in the break-in period I was just conflicted about the manual stating that I shouldn't run it full throttle until after the first 50 hours. My plan is to run for about an hour at 3000 then throttle down for awhile, disengage MMM, then repeat.
My other issue was low transaxle fluid (not on dipstick) which I'll post at some point.
Edit: I'll try to make a better video of it.
When the BX is used primarily for mowing during breakin, it is difficult to vary one's speed, as 3000 is needed. I wouldn't scream it all the way to 3200. If you mow in low as I do, 3000 is plenty fast enough to get a quality cut.
You'll have to find a way to put some hours on it at lower RPM. What joy!! I find that an engine, especially a diesel, like to really pull hard, as in pulling a disk, a rake, a box blade, a snow plow, something to push it hard during break-in. A few hours of this kind of thing at RPM between 2200-2600 will do it wonders. Reving along with no work pull on it (or worse, idling) isn't ideal.
As for the low fluids, sadly, this is almost SOP on Kubotas delivered. The front axles particularly work out air pockets. Check it frequently for a month. As for the HST being low, dealer prep is sometimes shaky, imho.
This leads me to doing my own service maintenance as per schedule and avoid the inconvenience of transport and the very high service fees.
   / BX2660 MMM vibration #13
As I understand it, the vibration starts when the mowing deck is engaged. If this is the case I would remove the mowing blades on the deck and check for balance. Checking for balance on a mowing deck blade is simple, if you have a vise, place a bolt in the vise and place the mounting hole in the blade on the bolt. The heavy end will fall. Remove blade material from the heavy end until each blade hangs level. In the absence of a vise, drive a large nail into a tree or other non moving support.
   / BX2660 MMM vibration #14
I have gone through two belts on my deck in about 175 hours of mowing on my BX. I've noticed my belt almost has a resonance(sp?) at certain RPM's, and flops around quit a bit, but I don't really feel a strong vibration. Like someone else suggested, check blade ballance, and also check to make sure the pulleys and all the bolts are tight on the deck. Some people have reported the pulley bolts or spindle bolts working loose on their decks.
   / BX2660 MMM vibration #15
I got a new bx2660 nearly a year ago. The salesman went thru checking all the fluid levels with me. All showed to be full.
I read about the front end fluid level getting low on this forum, so I went out and checked mine. Sure enough it was not even showing on the stick. I don't recall the hours but I'm sure it was less than 20.
Sure glad someone pointed this out.
   / BX2660 MMM vibration #16
Hard to tell from the video but you do seem to have more vibration than may be normal - again hard to tell without feeling it personally. Mine will noticeably vibrate from about 2,000 RPM up to about 2,700 or even 2,800 then smooth out real nice. When it was new, I mowed at around 2,800 to stay below max RPM but high enough to not vibrate too much and to get an even cut. I would, if I were you, check the bolts and belt and perhaps remove and check the balance of the blades just in case. Good luck and have fun breaking it in.
And as far as sitting through the video warm up time, I just fast forwarded through it while enjoying the flashing views of your new BX:laughing:
CATERPILLAR 289D3 SKID STEER (A60429)
CATERPILLAR 289D3...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
KOMATSU D155AX-8 CRAWLER DOZER (A60429)
KOMATSU D155AX-8...
2014 International Maxxforce DT (A53317)
2014 International...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
