Tire Selection Calculating ground contact and PSI
   / Calculating ground contact and PSI #11
IS the loader tractor 2wd?
Takes weight off drive tires? Adds mass amounts of weight over SMALL and SKINNY non-drive tires?
Answer is simple, get a 4wd loader tractor.
...or put a whole lot more ballast on rear of heavy 2wd loader tractor.
I think what works better depends on the conditions. Is mud "bottom less"?
Sometimes you want to be light (low psi) so you can float on top of surface (mud, snow, - I know nothing about driving on sand) and as long as surface can handle the lateral/horizontal (propulsion) forces from the tire and you don't rip up the surface to where you sink, you can keep floating and going.
Other times you want a narrow tire to dig through the mud/snow and have enough weight (psi) so that there's friction for it to bite instead of spin.
You need an onboard air compressor!! Adjust Tire Inflation Pressure On the Go
You honestly cannot see why a loader (even empty) overhanging the front axle effects the weight carried by the front?
Tractors of all sizes and all makes are scaled fairly proportional. Sure there are standouts and some are the exception to the rule....
But an "average weight" 20 hp tractor, 40hp tractor, and 60hp tractor....will all share a similar ground pressure, and a similar tendency or resistance to get stuck in the mud. Because as size/weigh go up....so does tire size in a fairly proportional manner.
Meaning that if you have an average 30hp tractor with loader that has a tendency to get stuck in the mud.....going bigger or smaller isnt going to change anything.
You need to change ANOTHER variable. IE: REAR BALLAST if 2wd, going to R1 tires instead of R4, or going to a 4wd machine instead of a 2wd.
No, sorry, I do know how a heavy loader overhanging will add to the weight. I get there's a lot of leverage. I was asking like how should I figure the added weight of a loader, factoring in the leverage etc. Anyone know?
Far as I can tell, my mud is "bottomless" and I'm attempting to float as much as possible.
   / Calculating ground contact and PSI #14
...Agreed that this isnt a simple and straight forward calculation...
Ditto that...something not mentioned (unless I missed it) is the motion factor...there is a significant difference between a static weight and a dynamic load as motion is applied...
...But on the lighter side...I've never seen a (working) tractor with spoilers...:D
   / Calculating ground contact and PSI #15
Yes it's 2wd. 4wd is too expensive, don't have the money. Plus my issue isn't 2wheel drive, it's sinking into the mud. I've never been stuck with my light tractor because I never sink in
Yes your issue is 2 wheel drive. Not completely but a significant part. A driven tire will always try to pull itself out of the mud where as an idling tire like a front tire on a 2 wheel drive tractor will tend to push into the mud. Then add the weight of the loader on the front tires and you compound the problem. Now add the weight of whatever you are carrying in the bucket and you've made the problem even worse.
To attempt to solve the problem you need to either get 4 wheel drive or only drive on dry ground. Or you could add enough counter weight behind the rear tires to attempt to take weight off of the fronts or you could try to carry the load with the rear tires. IE on the three point hitch.
   / Calculating ground contact and PSI #16
IMO...if you can not get even a 2wd tractor out of the mud with a front end loader you are operating in too wet of an area...know the limitations and capabilities of your machines...wait until the conditions change or change the conditions...!
   / Calculating ground contact and PSI #17
Slash pine is spot on. I won't go out on my property in early spring. Just too soft and mushy. Had I needed the info - I could have obtained the weight on the rear tires. I drove the tractor in to the ADM(Archer Daniels Midland) grain scales for a TOTAL weight - a few years ago. Just park it with the rear tires only on the grain scales - wallah.
   / Calculating ground contact and PSI #18
You are looking for ground force. You need to know how the weight is distributed from front to rear of you tractor, i.e. 30% over the front axle 70% over the rear? You need to measure that first. Then you take a contact patch measurement and divide the weight (pound force) by the are of the contact patch x 2 for the front, and then again for the rear. It's really not complicated, but you need to know your tractors weight distributions first. I'll help you if you do the homework that I just assigned. There are many ways to gets the weight distributions, but you'll have to know that before we can successfully make that "psi" (force per area) of the ground that you desire.
   / Calculating ground contact and PSI #19
Are you kidding? You don’t understand how a loader adds weight to the front non drive wheels? As to how much weight driving it across a scale is the only way to find out.
Yes, I'm basically guessing at the weight distribution at the moment. I don't have any way of really measuring that. Especially with the loader added in over the front, makes it more difficult.
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2021 Chevrolet Tahoe SUV (A56859)
2021 Chevrolet...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
Kubota Utility Cart (A59228)
Kubota Utility...
