Can anyone help me identify this Tractor?
   / Can anyone help me identify this Tractor? #11
Definitely not Belarus. The 2-cylinder model (250) is air-cooled and is laid out as described by jesnic. They also have a full width flat floor above the transmission.
Sounds like a cracked block. Perhaps you could fit up a different engine.
Thanks for everyones help. I had a Tiashan before and there are a few items that look like it so I will try looking there. Thanks Again
   / Can anyone help me identify this Tractor? #13
Yep, the learned amongst us have steered you in the right direction. Not a Belly.
It's ChiCom in nature. Start there. All sorts of ChiCom tractor help on the net. It's the latest Belarus/Zebra/Rhino fad to sweep the market.
Just look out for pot metal, bad fittings, indescribable gaskets, and, myriads of net hucksters looking to "help" you out, capiche.
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
