Can anyone identify this old hay rake????
   / Can anyone identify this old hay rake???? #11
Looks sort of like an old New Holland, but a bit different from the ones I have seen and used. Pretty good old rakes.
Baler is a new holland so mabey the rake is also. -phillip
   / Can anyone identify this old hay rake???? #13
It looks like a John Deere model 851 that was introduced around the mid-fifties.
Someone on agriculture.com said it looks like a JD 894. That's two votes for JD anyway. I couldn't find a pic of the 894, I'll look for a 851 pic. Thanks, Phillip
I found a pic of a rake that a guy thinks is a 851 or a 858. It looks the same as mine. Here is the other guy's rake. Does anyone know the difference between the 851 and 858? Thanks, Phillip
   / Can anyone identify this old hay rake???? #16
Yep JD or New holland, I believe New Holland made the JD rakes. Get parts from New holland, cheaper than buying parts from JD.
New hollands look similar but are different from what I've seen. They usually have 5 or 6 rake bars rather than the 4 on this one and their adjusting handles are mounted about 8-12 inches above the top of the frame. Later JDs had more rake bars but they were mounted on a round wheel, the new hollands are pretty much all on a star. -Phillip
   / Can anyone identify this old hay rake???? #18
I know its not a New Holland rake. I spent too many years in my youth assembling NH 55, 56, 256, etal rakes. I was going to guess that it was an Oliver rake. The rear viewing picture of the rake is hooked up to an Oliver tractor. There may be a brand connection.
OrangeGuy
   / Can anyone identify this old hay rake???? #20
It is not NewHolland. Would appear to be a JD, tho I don't follow them that closely.
Look over the frame very closely, esp near (not on, but near) the gearbox, and on all flat spots of the frame. You should find a serial / ID tag that will give the make & model.
--->Paul
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2014 DRAGON 130...
WHIRLPOOL WASHER & KENMORE ELITE DRYER (A54757)
WHIRLPOOL WASHER &...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
