Can I change hydraulic filter without draining fluid?
   / Can I change hydraulic filter without draining fluid? #21
Thanks all for your responses. In my case the fluid is about 6 inches below the fill port so I am going to try the vacuum (with a slight air leak). My John Deere Manual specifically says to prefill the new filter 1/3 to 1/2 full with new fluid. It even shows a picture with a funnel inserted in the center hole of the filter
As this horse gets beat to death, I've come to a compromise. I add sufficient oil for the filter media to soak up the oil Once soaked maybe a just a tad more but not enough to run out as I place it in a horizontal position and then install. Still achieves the goal of reducing dry time as fluid lows through during start up. :thumbsup:
   / Can I change hydraulic filter without draining fluid? #22
I wonder if this suck hole method will work to hold the antifreeze in the block while installing a freeze plug style block heater?
   / Can I change hydraulic filter without draining fluid? #24
can't see why it wouldn't long as the AF was low enough in the neck of the rad............Mike
   / Can I change hydraulic filter without draining fluid? #25
Ha, ha - - four years ago - when changing hydraulic filters - I tried the shop vac trick. There is still a large spot on the lawn where the grass will not grow and - I now have a new shop vac. All-in-all - - I feel rather fortunate that the original shop vac didn't go up in flames and smoke. Live and learn.............
   / Can I change hydraulic filter without draining fluid? #26
^^ Well, that's part of my concerns. I can see how this may work on larger transaxles with bigger ports, but not on the smaller ones.
I'm thinking about trying to bend a piece of 1/2 copper tubing to go just barely down into the opening and connect to a smaller shop vac. But I'm still not wild about the prospects.
   / Can I change hydraulic filter without draining fluid? #27
The concept is great - if you can fabricate a system that will work. In my case it could mean - not having to catch 16+ gallons of hydraulic fluid and then getting it back into the tranny. Unfortunately - my experience also shows - you wouldn't be staring at an ever growing puddle of hydraulic fluid.
   / Can I change hydraulic filter without draining fluid? #28
Well, I can do it in a dirt floored shed where spilled fluid could act as a termite treatment, so no issue there. Flamin' Shop-Vac is a different issue though.
   / Can I change hydraulic filter without draining fluid? #29
Yeah if you have your new filter ready and are fast. I usually run my fluid twice as long as recommended since mine is light duty but change the filter at the normal drain interval. I put a regular oil drain pan under the filter, get ready with the filter finger tight on the shaft and whiz old off and new on.
   / Can I change hydraulic filter without draining fluid? #30
When I pulled the filter on my L4060 it was off my machine for several minutes with a full sump of hydraulic oil. Only a few drops & lots of bong type noises made it out. No fiery death or any other problems. Unless you are dealing with gasoline or something else volatile a shop vac & sparks arent going to ignite anything. Additionally the sparks & motor are exposed to the air above the shop vac, not internally to the filter or dust bin.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
