Can I rebuild the hydraulic pump for a Mitsubishi MT 372 D/Satoh 370 Beaver
   / Can I rebuild the hydraulic pump for a Mitsubishi MT 372 D/Satoh 370 Beaver #31
With the top piece of the assembly not shown on the left they do look different but now that I look at again I guess they probably are the same. The camera must have been closer to the one on the right.
   / Can I rebuild the hydraulic pump for a Mitsubishi MT 372 D/Satoh 370 Beaver #32
PILOON;
I think I can envision what you wrote but can you post a picture of your setup? I'm new to all this and I would like to wrap my head around what you wrote.
Thanks for the help.
As much as I'd like to it calls for removing the battery and tray + front grill also at present my snow plow is still mounted.
Heck I actually went out with my camera to take a few pics until I realized what all was in the way.
The factory PN's are (from the MT180D parts catalogue) for the K3C engine.
1019 5402 OCO --flange
67495-90200---coupling
Now I recall that I had actually purchased these 2 parts at the time since accuracy would be difficult with my limited tools at that time.
Holy smokes people, does this thing move some dirt now! Before I would only be able to sink my FEL in a couple inches then I wouldn't be able to lift my bucket. So I would only skim the top as best as I could until I hopefully got enough dirt worth while to move. And if I did get enough dirt worth while to move I wouldn't be able to lift it.
I still have to skim since I don't have a big tractor but I can skim deeper and lift my bucket when needed and get a bucket full of dirt. It's a lot easier to manipulate the bucket in the dirt when needed to get more dirt. I can lift the bucket full of dirt over the dirt pile now as well.
Thanks for all your help on the issue being "bypass"! I never knew what it was and I never would have suspected it either since my bucket lift pistons didn't leak.
You guys rock, I hope I can contribute to others as well.
   / Can I rebuild the hydraulic pump for a Mitsubishi MT 372 D/Satoh 370 Beaver #34
Congratulations :thumbsup:. Thanks for letting us know it worked out.
   / Can I rebuild the hydraulic pump for a Mitsubishi MT 372 D/Satoh 370 Beaver #35
It is pretty straight forward. Unhook lines, unbolt pump. Reverse procedure.
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A51573)
New/Unused 4ft...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
