RobertN
Super Member
Did you go over all the major wire connections? Make sure they are clean and tight? Not just by looking... That has bit me before. Remove the battery cables at the battery, and the chassis ground, at the starter ect. Make sure each connection is bright and clean. Make sure the cables are not corroding up under the shielding. Check each wire with an ohm meter. Visually check each wire, even if have to open up the wire loom.
95% of the time, that has been the issue I run in to. My Dad was terrible frustrated with his 9N not starting. He took the starter out, thought he needed a new solenoid. I put the starter back in, then took each cable, and wired brushed every connection bright and clean. Hooked it back up, and it started.
It sounds like you have something resistive, generating heat, and pulling current.
Funny, a couple months ago I had a 12V wire problem on my 5th wheel. Worked fine when I parked after a trip a couple months ago. It was 10PM the night before we were supposed to leave on a campout. No lights in the RV. I dinked and dinked and dinked with that thing. Finally, was trying to ohm between a ground and another point, that I could not reach AND hold both probes. My wife cam out to hold one probe on a ground, while I was reaching way inside a storage compartment. She bumped the ground wire, and it sparked.
Shazam! I had done a visual on that connection, but did not disconnect and clean it. 5 minutes later, everything worked great...
I am going to check the tractor again tonight. This time with the lights off to look for arcing. If I don't find any, I am going to take a look the red wire that comes out of the VR and goes to the starter switch/starter solenoid. That is the place that seems to be generating the most amount of heat and then it seems to travel down the red wire and through the VR connector. Then it heats up the VR.
I am wondering if maybe this red wire (which is a larger gauge and apparently is a fusible link that is designed to fail if there is too much current) is not making a good connection and is overheating as a result.
Who knows, it could be anything!!!
