Can I turn up the hydraulic pressure?
   / Can I turn up the hydraulic pressure? #1
BobQ
Conn
Can I turn up the Hydraulic pressure on my backhoe with out doing damage? I have never checked the pressure before but assume it is OK. I just want to get a little more out of it? Also, what would be the max pressure so I can check it, to see where it is? This would be on my 4720 with the nine foot hoe.
Thanks Bob
   / Can I turn up the hydraulic pressure? #2
I am not familiar with your unit but could raise your RPM? Or try the relief valve
Jim
The hoe is the same as a DJ 48. I plan on putting a guage on it this week end to see where the pressure is at.
Bob
   / Can I turn up the hydraulic pressure? #4
I checked my shop manual for the proper hydraulic pressure specification for my tractor. Then had it checked at the dealer... it was slightly below spec and they added a shim/spacer/washer in the pressure relief valve.... increased slightly over spec the pressure before the relief valve would open. Am speaking of a Kubota. I assume that there are similar relief valves on other makes as well and that they, too, are adjusted via some sort of shim device or adjustment.. It made a big difference in max pay load weight I can now pick up with FEL.
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
1999 MATE END DUMP TRAILER (A52472)
1999 MATE END DUMP...
