Can you braze a hydraulic line?
   / Can you braze a hydraulic line? #81
Can't wait to break something so I can test this out! :LOL:
   / Can you braze a hydraulic line? #82
Before there was duct tape, there were steel coat hangers. The original multi-purpose DIY that was always close at hand.
My wife has replaced all of the house coat hangers with plastic, But I kept a dozen or so in the garage because sometimes that is all you need is a little piece of coat hanger to do a task where nothing else seems to work. :cool:
In the middle of nowhere Oklahoma I helped a man fix his truck. I found another truck. We cut the bent frame off his and cut the straight part off the other. Welded truck together with brown clothes hangers and a torch. Right there in the pasture.
   / Can you braze a hydraulic line? #83
Joint fit is critical for proper brazing joint strength. Metal cutting bandsaw blades can be brazed together and last the life of the blade. Tough test for any joint. Properly done the bonding strength exceeds the mechanical properties of the filler metal. Depending on the crack size, deformation, patch fit or tightly wrapped wire adds to bonding strength. The OP’s successful repair is just the small amount of material bonding at the split edges not a large puddle on top. Having experience brazing helped the OP too.
Long ago demo a well used, farm grade Ford 3500 backhoe. Strong machine that obviously had the hydraulic pressure turned up. Almost every hard line at bends had rough brazed repairs on the loader. Didn’t buy that one but the hook had been set.
Monitor hydraulic line pressure on the loader of my M59 with a gauge installed with a soft ride system. Max pressure slightly below of range spec. Thought about increasing the pressure relief but the machine is already scary strong. With OP experience feel better about leaving the relief pressure on the low side.
   / Can you braze a hydraulic line? #85
I've got to remember that trick, too. It's a good one.
The resulting composite of steel and silver stands a decent chance of being better than either alone. I'd love to see some formal testing.
rScotty
Y'all should get togeather and tear something up then try to fix it.😜
   / Can you braze a hydraulic line? #86
Been in the hydraulic business for over 25 years. Alot of the fittings you buy are 2 piece brazed fittings. I have field repairs that have been holding at up to 6000psi for years now on fittings and many lines that were mig or gas welded. I quit brazing them 30 years ago when I learned to weld. Braze will hold on a fitted joint but not normally a hole or Crack unless there is enough build of the filler and it is relatively low pressure. If the line is basically empty the heat will eliminate any oil residue. Compression fittings are good through 5000psi and 2 piece ferrules will hold stainless steel lines well beyond the line pressure ratings. Cj
   / Can you braze a hydraulic line? #87
The Navy taught me to braze (and weld) in 1971,,
After practicing, we were given an assembly of several size pipes, and plates that resulted in a container with a 3/4" NPT pipe.
The pipe could be mounted in the booth at any position, but, not moved after we started.
We oxy-acetylene welded one, then oxy-acetylene brazed the other.
Then, they screwed the assembly to a pump that put water in the assembly, and recorded pressure.
Several of us in the class brazed and welded both assemblies to be able to make it to the max pressure of 3,500 psi.
The instructor was surprised, usually only one guy maximum in the class could get both to max pressure,,
We also silver brazed Inconel pipe to some fitting that had an included silver solder ring,
That was kind of easy, if you were willing to take the time to clean the parts perfectly.
And we brazed cast iron bars, about 1/2" thick, the bars formed a simple butt joint.
The finished assembly was put in a press,
the braze had to hold, and the cast iron bar had to break next to the braze joint.
I think they were only trying to teach us that a braze joint could be incredibly strong,,
   / Can you braze a hydraulic line? #88
Just because
When making a repair to a pressure line, (I have no issues with a brazed patch, cleanliness! Clean! and clean again, brake cleaner is your friend!) be aware that a pinhole can allow a spurt of oil that can cut through flesh like a hot knife through butter.
Wrap the "wound" with paper towels or shop rags when doing the after repair proof testing.
Don't ask me why I'm writing this.
   / Can you braze a hydraulic line? #89
Just because
It did not happen,,, without pics,,, of the bandages,,, :ROFLMAO:
   / Can you braze a hydraulic line? #90
Yup on the PHD when it comes to filler. When a politician uses the term it's reference is to BS.
12ft Shipping Container (A54865)
12ft Shipping...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2014 Kubota M8560 (A53314)
2014 Kubota M8560...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2020 Bobcat S850 Skidloader (RIDE AND DRIVE) (A50775)
2020 Bobcat S850...
2020 Kubota M6H-101 (A53314)
2020 Kubota...
