Can you identify this PTO Shaft
   / Can you identify this PTO Shaft
   / Can you identify this PTO Shaft #12
You may have just changed my life!
You are right, the ones at TSC were about $125 -$150 minimum.
Now I'm going to burn more time shopping... ;)
Hey, it's what we TBN'rs do. We change lives, we help other members spend their money, etc. ;-)
   / Can you identify this PTO Shaft #13
I actually had someone steal the front half of my PTO shafts out of my back yard. Took 3 complete ones that were not hooked to anything. Sheriff David J. Westrick. was not even going to require a report. Thank you for supplying the ag link. Half shafts are hard to come by. I for one liked to see scrap prices tumble.
   / Can you identify this PTO Shaft #14
powerscol is exactly right - the issue is that I can't get the shaft off of spreader. There has already been lots of penetrating oil, force, cussing, heat, etc attempted.
The idea was to buy tractor side half shaft that would fit the one rusted on. My local TSC does not offer a shaft with the same cross section as this one (thus the reason I asked for help identifying the shaft).
I have 2 other alternatives:
1) Take the u joint apart and connect another shaft that way (will require some research to see if the yoke will fit the shaft).
2) Cut the yoke off and replace - research to see if a replacement PTO shaft will fit the shaft on the spreader.
One other thing you can try as a last resort. Get a cutting wheel on a grinder and slit the shaft lengthwise at the connection. Be very careful not to cut into the spline on the unit. Then use a cold chisel and split the outer casing - or find a shop willing to do it for you :thumbsup:
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
