MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,975
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
joshuabardwell said:Well, now, that's interesting, and has got my mind working. My tractor has a low oil pressure light. With a little creativity and some relays, I bet you could easily wire that to blow the horn when it's on as well. Only problem is, the light comes on when the key is turned, but the engine is not running, and that would be annoying. Is there some lead that only has current on it when the tractor is running, and not just when the key is turned? That way, you could wire it up so that if the oil pressure light is on and the engine is running, the horn blows. My tractor is a diesel, so in theory it doesn't need electrics to keep running. On the other hand, something shuts down the engine when I turn off the key. What is that?
Engine oil pressure and timer. Oil pressure at start to activate relay providing power to the warning system, but with a timer so if pressure never achieved, warning system is activated.
We have models with both power to run and power to shut down. Power to run, something happens to the electrical the engine will immediately shut down. Power to shut down if you lose electrical you need to open the hood and hold the manual fuel cut-off switch until the engine dies. Or you can do what I recommended we put in the book - slap the cap the dealer gave you over the air intake.
With the larger engines and Tier 3 we started doing everything with the engine ECM so all sensors fed the ECM and it controlled warning lights, audible alarms, and we started doing things like automatically debating the engine in case of overheating or boost power if conditions said more power is needed and there was enough margin (like coolant temp) to over boost for a limited time.
