Oil & Fuel Can't Believe This Happened
   / Can't Believe This Happened #61
joshuabardwell said:
Well, now, that's interesting, and has got my mind working. My tractor has a low oil pressure light. With a little creativity and some relays, I bet you could easily wire that to blow the horn when it's on as well. Only problem is, the light comes on when the key is turned, but the engine is not running, and that would be annoying. Is there some lead that only has current on it when the tractor is running, and not just when the key is turned? That way, you could wire it up so that if the oil pressure light is on and the engine is running, the horn blows. My tractor is a diesel, so in theory it doesn't need electrics to keep running. On the other hand, something shuts down the engine when I turn off the key. What is that?
Engine oil pressure and timer. Oil pressure at start to activate relay providing power to the warning system, but with a timer so if pressure never achieved, warning system is activated.
We have models with both power to run and power to shut down. Power to run, something happens to the electrical the engine will immediately shut down. Power to shut down if you lose electrical you need to open the hood and hold the manual fuel cut-off switch until the engine dies. Or you can do what I recommended we put in the book - slap the cap the dealer gave you over the air intake.
With the larger engines and Tier 3 we started doing everything with the engine ECM so all sensors fed the ECM and it controlled warning lights, audible alarms, and we started doing things like automatically debating the engine in case of overheating or boost power if conditions said more power is needed and there was enough margin (like coolant temp) to over boost for a limited time.
   / Can't Believe This Happened #62
1 key switch off
2 accessories on
3 accessories on and engine running (check for relay for this position and make sure relay is big enough to handle extra load)
4 accessories on/off and starting engine (release key causes it to go back to (3) above)
   / Can't Believe This Happened #63
1 key switch off
2 accessories on
I'm sorry, but I don't follow what you are trying to describe here. Condition (3) is what I am trying to detect.
   / Can't Believe This Happened #65
What about just using a good old-fashioned buzzer tied in with the oil warning light?
   / Can't Believe This Happened #66
As far as vandalism, many years ago at a nearby tire distributor, Vandals got into this distributor's fenced yard and loosened the drain plugs on about 20 delivery trucks. As the day progressed and the drivers started calling in with broken down trucks, there was no way to warn the remaining trucks to stop as this was in pre cellphone days. If I remember correctly just about all the trucks were damaged. Things like this can and do happen.
James K0UA
   / Can't Believe This Happened #67
It would be nice if a buzzer went off through the radio speakers when it got hot or lost oil pressure.
   / Can't Believe This Happened #68
I did this on my airplane. If oil pressure, buss voltage, or vacuum goes low I get warning tone in my headset.
   / Can't Believe This Happened #69
James K0UA
No one noticed any puddles of oil when getting in their trucks? I'm not doubting what you're saying. I could see this easily happening especially if the trucks were parked on dirt or gravel.
If I spill a half a pint on concrete and seems to cover a 3' circle before I can get it cleaned up.
   / Can't Believe This Happened #70
He said they loosened them. I suspect they fell out on the road. Must have been pretty loose.
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
JOHN DEERE 772GP MOTOR GRADER (A58216)
JOHN DEERE 772GP...
2013 Hyundai Veloster Hatchback (A56859)
2013 Hyundai...
2020 Kubota Z421 Mower (A57149)
2020 Kubota Z421...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
UNUSED FUTURE BS72 72" HYD BOX BROOM SWEEPER (A58376)
UNUSED FUTURE BS72...
