Oil & Fuel Can't Believe This Happened
   / Can't Believe This Happened #11
Lesson learned. Always check your fluids before starting out for the day.
Standard practice for any competent equipment operator.
Hope you can get out of it without costing you too much.
That lesson was learned a long time ago.
I check all fluid levels before each use. But that doesn't protect you if the drain plug backs out.
I suppose I should check all drain plugs before each use.
   / Can't Believe This Happened #14
New (to you) machine. First thing that should have been done would be an oil change (at minimum). A check of the other drain plugs is good advice too. Then you would know where you were starting from.
On my BX, it was still tagged with the mechanics tag from its PDI at the dealer, I still went underneath and gave a quick torque on the engine and axle plugs. You never know.
Considering all the things that could have happened to a used machine in its life, a complete service and inspection at arrival is cheap insurance.
   / Can't Believe This Happened #16
Ahhhh man I hope it fires up after a cool down and some fresh oil.I'm always torn between not tightening the drain plugs enough on my motor and over tightening them and stripping it out.I hope you catch some luck on this one.
Brian
That is why they publish a torque specification.
   / Can't Believe This Happened #19
Never seen anyone put a torque wrench on a drain plug in my lifetime.
Brian
I never have either, and in 28 years of doing my own service countless number of times, never had one come loose. Philip.
   / Can't Believe This Happened #20
That's because you have done it enough times to know what the torque approximates and are good at what you do.
I'm 63 and have done it twice. Once a number of years back on a very expensive car with an aluminum oil pan and an aluminum pan nut with, as I recall, an O-ring seal. Also did it on my current 2011 Toyota Tundra that has a cartridge oil filter--not a cannister--and has a torque # for the cap that has an O-ring and a torque # for the drain cap--that has an O- ring and sits inside the cap. I think the EPA geniuses thought up this cartridge oil filter thing.
I can't recall ever torquing any other oil pan but for some guys that don't have enough experience or confidence and have plenty of free time, a torque wrench give a measure of self-assurance so they won't need it the next time.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bradco Paladin 6 Way Blade Skid Steer Attachment (A59213)
Bradco Paladin 6...
HYUNDAI 140LC-9 EXCAVATOR (A52709)
HYUNDAI 140LC-9...
KBH 25T Tender (A56438)
KBH 25T Tender...
2315 (A58376)
2315 (A58376)
