CATMAN
- Joined
- Jun 23, 2006
- Messages
- 320
- Location
- South of Seattle
- Tractor
- Dad's=JD4440;IH1066;JD4020;JD3010;2 JD"B" 1949 & 1937(hand-crank)
If Wayne county hose' method, doesn't work for you, then try this IF you can get a "backup" wrench on to the o-ring fitting's hex. Put on both open-end wrenches onto their fitting's and put both wrenches straight up(or parallel) to each other. Now, get a prybar or piece of flat steel(lever) and wedge inbetween the two wrenches at a 90 degree angle and with some prying motion and pushing downward of the prybar one can sometimes get the fittings to break loose.
I know it seems like you need three hands to do this procedure, but I have used this method many times on fittings that were in bad locations and I was working at arms' lenght where I didn't have the leverage/physical strenght to loosen fittings.
I can only hope you understand this description, but I don't know of a better way of wording it. Basically, the prybar provides the force/mechanical leverage on the open-end wrenches, the farther you push and "walk" the prybar downward inbetween the "beams/handles" of the open-end wrenches then the fittings should be loosening up.
