Can't get steering wheel off
   / Can't get steering wheel off #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Can\'t get steering wheel off
My 180D is real pretty except for the dash. Had a new paint job before I bought it, but they did nothing with the dash, which was cracked and a couple lights had popped loose. Got a buy on a new dash and am trying to pull the steering wheel so I can install it but so far, no go.
I have used liquid wrench & automatic transmission fluid, which I have heard is a good penetrating oil. Have cut a slot in a big, beefy washer to put under the steering wheel so I won't mess up the wheel, then tried pulling it with a gear puller, but it just tips to the side when I tighten it up. Dealer's mechanic says to be careful hammering on the end of the column as it could mess up the threads at the lower end, so I haven't hit it hard.
Any other ideas?
Thanks.
Any other ideas?
Thanks.
   / Can't get steering wheel off #3
Re: Can\'t get steering wheel off
I screw the nut down flush with the end of the steering column and while pulling up on the outer part of the steering wheel I hit column with BRASS HAMMER. Notice I said BRASS HAMMER!!!!!
   / Can't get steering wheel off #4
   / Can't get steering wheel off #5
If your's, is as stubborn as mine was /forums/images/graemlins/crazy.gif Maybe you will have some luck doing as I did. I sat on my seat and placed both arms on underside of steering wheel on both sides. Then pushed up with my knees under my arms. While a friend hit the column with a hammer. And do as eddie says, !!!BRASS HAMMER!!!.
Mine came off after a couple of good whacks.
   / Can't get steering wheel off #6
   / Can't get steering wheel off #7
Why a brass hammer, as long as you are hitting the nut and not the shaft? A thin, flat legged puller from an autoparts store, ($6), should work fine and not mar the wheel.
   / Can't get steering wheel off #8
   / Can't get steering wheel off #9
With a regular hammer you will either damage the nut or the shaft. DON'T ASK ME HOW I KNOW.
The problem with using a puller is I think you're pulling against the plastic part of the steering wheel.
   / Can't get steering wheel off #10
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED CFG INDUSTRIAL MX20R EXCAVATOR (A51247)
UNUSED CFG...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A51247)
1996 UTILITY 101"...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
