Can't get steering wheel off
   / Can't get steering wheel off #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Can\'t get steering wheel off
My 180D is real pretty except for the dash. Had a new paint job before I bought it, but they did nothing with the dash, which was cracked and a couple lights had popped loose. Got a buy on a new dash and am trying to pull the steering wheel so I can install it but so far, no go.
I have used liquid wrench & automatic transmission fluid, which I have heard is a good penetrating oil. Have cut a slot in a big, beefy washer to put under the steering wheel so I won't mess up the wheel, then tried pulling it with a gear puller, but it just tips to the side when I tighten it up. Dealer's mechanic says to be careful hammering on the end of the column as it could mess up the threads at the lower end, so I haven't hit it hard.
Any other ideas?
Thanks.
Any other ideas?
Thanks.
   / Can't get steering wheel off #3
Re: Can\'t get steering wheel off
I screw the nut down flush with the end of the steering column and while pulling up on the outer part of the steering wheel I hit column with BRASS HAMMER. Notice I said BRASS HAMMER!!!!!
   / Can't get steering wheel off #4
   / Can't get steering wheel off #5
If your's, is as stubborn as mine was /forums/images/graemlins/crazy.gif Maybe you will have some luck doing as I did. I sat on my seat and placed both arms on underside of steering wheel on both sides. Then pushed up with my knees under my arms. While a friend hit the column with a hammer. And do as eddie says, !!!BRASS HAMMER!!!.
Mine came off after a couple of good whacks.
   / Can't get steering wheel off #6
   / Can't get steering wheel off #7
Why a brass hammer, as long as you are hitting the nut and not the shaft? A thin, flat legged puller from an autoparts store, ($6), should work fine and not mar the wheel.
   / Can't get steering wheel off #8
   / Can't get steering wheel off #9
With a regular hammer you will either damage the nut or the shaft. DON'T ASK ME HOW I KNOW.
The problem with using a puller is I think you're pulling against the plastic part of the steering wheel.
   / Can't get steering wheel off #10
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2025 CFG Industrial MX12RX (A50123)
2025 CFG...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
Athey 7-12 Force Feed Loader (A52384)
Athey 7-12 Force...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
