Sorry chaps , im in bed while you guys are talking . God should have made the earth flat and it would'nt be a problem . Whatever size thread you want to cut be it a bolt hole or a grease nipple hole , hold the bolt/nipple up to the light and put the shank of a drill bit in front of it (between you and the nipple). If you can see ALL the thread on the bolt/zerk protruding above and below the drill bit you have chosen the correct drill for the job . I would'nt bother taking out the pin , use a hand drill and leave it in situ . The grease in the pin will catch the swarf and you can remove it with a piece of wire . When using a tap make sure you don't go further than a 1/4 turn clockwise before turning back counter clockwise to remove the swarf , then proceed forward another 1/4 turn and keep repeating these steps untill you are in far enough with the new thread . If you go further than 1/4 turn you will break the tap in the hole , HELLO NEW PIN . 1/8th gas is an imperial sized nipple , it's one i use when i need a bigger nipple for the same purpose . Its hard to diagnose something you have not seen half way around the world . But before you go to the trouble of going to a bigger size have a good look at the hole you have . If the nipple is simply broken off , the center portion of the nipple can be drilled out and be tapped the same size as the original so an identicle nipple can be inserted . This usually chases the old male thread out and cleans the old female hole to take another nipple the same size . To determine what size drill to use for this proceedure take out another nipple from another pin and look at what size the shank on the nipple is without the thread . Drill the hole to this size , get a tap that will screw into the good pin you got the nipple from and screw into the crook pin using the steps above . (Tip) NEVER grease the loader while it is raised , doing so will force grease to the loose side of the pin as the other side (the working side)is metal to metal (pin against bush) and wont get any grease . The pins dont rotate far enough to spread the grease around the pin so undue wear will result .
