Capacity of tag along vs GN
   / Capacity of tag along vs GN #1
Montana_Jack
Kubota M-5700 & BX 2230
I have an F350 with a hitch rated for 12,500lbs. Would I gain any increase in tow weight with a goose neck?
   / Capacity of tag along vs GN #2
Usually. Many folks run 24k trailers pulled by 3500's or dodge 1 ton duallies.
What does Ford say?
jb
   / Capacity of tag along vs GN #3
Yep, probably 2X or more. Think of a regular PU truck and trailer as just that a PU truck and trailer. Think of a PU truck with a goose neck as a small tractor trailer.
The main advantage of the 5th wheel hitch is the weight distribution. When you have a regular hitch all of the weight is behind the rear axle and with enough weight can start to raise your front end off the ground. With a 5th wheel hitch the weight is located over your rear axle and distributes the weight evenly over the truck which makes for safer handling.
   / Capacity of tag along vs GN #4
My F250 (SRW) is rated 12500/1250 at the hitch with a weight distributing hitch and 6000/600 with a conventional hitch.
Gooseneck/fifth wheel rating is 13500 lbs (the same ratings go for F350 SRW)
The F350 dually version in 8000/800 conventional 15000/1500 Weight dist. hitch and 15000 gooseneck.
I don't think you will find any pickup rated over 8000 LBS without requiring a weight distributing hitch.
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
18002 (A51691)
18002 (A51691)
2014 Ag Spray Schaben Sidedresser (A52748)
2014 Ag Spray...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
