Capacity of tag along vs GN
   / Capacity of tag along vs GN #1
Montana_Jack
Kubota M-5700 & BX 2230
I have an F350 with a hitch rated for 12,500lbs. Would I gain any increase in tow weight with a goose neck?
   / Capacity of tag along vs GN #2
Usually. Many folks run 24k trailers pulled by 3500's or dodge 1 ton duallies.
What does Ford say?
jb
   / Capacity of tag along vs GN #3
Yep, probably 2X or more. Think of a regular PU truck and trailer as just that a PU truck and trailer. Think of a PU truck with a goose neck as a small tractor trailer.
The main advantage of the 5th wheel hitch is the weight distribution. When you have a regular hitch all of the weight is behind the rear axle and with enough weight can start to raise your front end off the ground. With a 5th wheel hitch the weight is located over your rear axle and distributes the weight evenly over the truck which makes for safer handling.
   / Capacity of tag along vs GN #4
My F250 (SRW) is rated 12500/1250 at the hitch with a weight distributing hitch and 6000/600 with a conventional hitch.
Gooseneck/fifth wheel rating is 13500 lbs (the same ratings go for F350 SRW)
The F350 dually version in 8000/800 conventional 15000/1500 Weight dist. hitch and 15000 gooseneck.
I don't think you will find any pickup rated over 8000 LBS without requiring a weight distributing hitch.
Mini Excavator Bucket (A53316)
Mini Excavator...
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
2022 Chevrolet Tahoe SUV (A55758)
2022 Chevrolet...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
Hose Reel for Vacuum Truck (A53314)
Hose Reel for...
2019 Start EV 36V Electric Golf Cart (A55758)
2019 Start EV 36V...
