Oldtrout
Yep Iron Horse, I buy the cheapest oil I can get by the case usually at wally world. The last case I got worked out to $1.98 a liter. I did use premium shell for a while and added stp still one liter /1000 km.
Hey Chris,
One thing might put a crimp in your plans to keep running it. If it continues to use a Qt/1K miles and you live where they have strict emission laws you may end up at a point where it won't pass emission inspection.
If memory serves me correctly, starting in '96 most car makers went to a closed loop engine management system. These use two oxygen sensors, one upstream of the cat and one down stream. The purpose of these is to monitor the cat and make sure that it's doing it's job. As oil does not burn completely, it will eventually foul the bed in the converter to the point where to voltage difference in the two sensors causes the engine management system to throw a code. (the converter won't last forever even if the engine doesn't use oil, but added oil smoke running through the exhaust will hasten the process) I ran a 97 Camry with this issue for several years, it would use about the same amount of oil and throw a code every 3 or 4 months.
Tom
Well, I changed the oil yesterday and used 3.5 qts of Mobil 5,000 5W30 and .5 qts of STP Oil Additive. I drove the car 120 miles last night and will check the oil level later today to see what happened.
Just a recap of previous post. Car calls for 5W30 with 10W30 being allowed in certain temps. Was burning 1 qt per 800 miles with both grades.. Believe its going past the rings. Car still averages 32 in town and 38 on highway so really don't want to tear down the engine and I also do not believe its bad enough to do so. Its a very cold Indiana winter so in spring I will try 10W40 if I get no results from the STP additive and the recommended 5W30.
I will keep you all posted.
Chris
Well I checked the oil today after 800 miles of driving on the 5W30 and STP. It was 9/10 of a quart low. So the oil consumption got just a tad better with the STP, maybe another 100 miles before it would be a full quart low.
Will changed the oil again in 2,200 miles and will be going over to Mobil 5000 10W40 and will post back the results. If no change I will then try the ATF trick John Bud suggested.
Chris
