Care of Septic Tank
   / Care of Septic Tank
Thanks everyone! The helpful comments have given me the info I needed.
It seems I'm doing OK with the way I'm treating the system, but I have some things to change.
I had no idea that extra water was a problem. I suddenly remembered that our toilets are low-flow and use 6 liters or 1.5 gallons per flush, so that is going to help. I'm going to try to figure out an alternative way to get rid of our gray water. Also, I'll be very diligent about stopping any leaks that develop. I already shut off the water supply when we are away.
I know who to call to find out about pumping out the tank, so I'll be able to have someone do that on a regular basis.
Thanks Again!
   / Care of Septic Tank #42
Rid-X - The longest running scam in history. There is nothing in it that a good "dump" won't provide.
I bought this house in 1976 with a newly installed tank/drain field. 2 persons mostly, dishwasher and laundry. Everything goes in the tank. I pump it every 5 years and even then it really doesn't need it. But then the soil here has good "perc". Even my wife's attempts to kill the tank didn't work. She was pourting bleach by the cupfulls in the toilet to clean it. Yellign at her didn't cure it. I finally had to hide out the bleach jug.
Harry K
What about those of us that take 80% of our dumps at work and therefor our tank is left out??
   / Care of Septic Tank #43
Does anyone else use a mesh filter prior to the septic pump? They sold it to me when I upgraded to a pump from the old gravity fed system (changed the tank at the same time). I clean the filter about twice a year. Crappy job!
   / Care of Septic Tank #45
Now I'm worried. Just bought a 120yr old house that previous owners lived in for 50yrs. They stated at closing they had no clue how long it had been since it was pumped.. I know it drains slow but I just thought it was because there are absolutely no vents in the system... This place has been a headache since day 1.
Off topic, but if you don't have any vents into the system, you are going to have slow drains! I'd be finding a way to get one put in.
   / Care of Septic Tank #46
Yeah, it's on the list of things to do. Like I said, this place has been a headache since day 1. Just got done with the electrical issues, now it's on to the plumbing..
   / Care of Septic Tank #47
My family has been in the septage business for over 50 years. Septic tanks take care of themselves. Adding yeast or dead groundhogs etc. is like throwing a cup of salt into the ocean to raise the salt level. Problems with septic systems are hydraulic overloading and organic clogging. Septic tanks are like the filters on our vehicles. They are there for maintenance to be pumped routinely, unlike the old cesspolls that only need to be pumped when they are full.
Septic tanks operate at a near full level with a baffle on the inlet pipe to keep inflowing sewage from distrubing and churning up the sewage in the septic tank. There is a baffle on the outlet line about 1" below the inlet line, this baffle keeps the floating scum, grease etc. from flowing into the drain field.
With normal use the septic tank with collect solid material on the bottom and light material on the surface. As the sludge and scum levels increase they decrease the amount of time new inflowing sewage as time to settle out causing the out flowing sewage to the drain field to carry over debris laden sewage. The septic tank can also be called a settling tank as it allows the grease, solid etc to settle out making for cleaner sewage to flow to the drain field. It is an antiarobic system which doesn't require oxygen. The use of cold water detergents that were popular a while ago contiained phosphorus to create the heat in the washing machine when mixed with water. It is our experiance that the phosphorus re-solidifies in the septic tank casusing a quicker build up of scum on the septic tank surface. To know when a tank needs to be pumped, a person can open the lid using safe practices on large openings,and check the thickness of the scum level on the surface of the tank. It should not be more than 5-8 inches thick. It is difficult to know how deep the sludge is on the bottom of the tank but if the scum level is little to none after 3-5 years it would be wise to pump it to find how your family use affects the system. If you have a garbage disposal, you should have your tank pumped more often because of the extra solids put into the system. The average pumping should be 2-3 years. Bragging that you haven't pumped your septic tank for many years is like bragging you haven't changed the oil filter in you tractor for years. If debris is carried over to your drain field the grease and detergent seals the pores in the soil preventing the water from being absorbed. This is called organic clogging. If your drain field becomes over loaded with sewage this would be hydraulic overloading. Organic clogging cannot be fixed, new drain field. Hydraulic overloading could be from a dripping spigot or running toilet, if you have to juggle the toilet flush handle, fix it, a running toilet can add an additional 28,000 gallons of water to a 1,500 gallon septic system in a year, thats a lot to expect the soil in the drain field to disipate. I hope this helps, relax flush you paper but not sanitary items, stop leaks and drips. Don't add anything extra and find a good sewage management company that has certification. I hope your find this helpful.
Thanks for the info. very helpful!
Thanks Again!
FYI- diverting gray water somewhere else is just fine - as long its not stored at all and where it goes is used right away.
   / Care of Septic Tank #48
Look for toilet paper that is labeled "septic safe" (we use Scott) ...some use cotton to make it soft and cotton doesn't dissolve in the tank.
   / Care of Septic Tank #49
I'll chime in. Wisconsin requires inspection/pumping every 3 years. The "Honey Wagon guy" can get a waiver on pumping depending on the amount of solids but he still has to check it. Fines are stiff ($500+ if you don't comply). The "Honey Wagon guy" is required to be licensed which requires annual code training. Having seen everything, he will be your best resource.
   / Care of Septic Tank #50
WOW!!!
Wisconsin has a bunch of socialist/ nanny state laws I have heard about. Im guessing this is why cost of living is so high up there? I work with a girl from one of the twin cities, she talks about how much construction costs are and how much her brother makes up there as a hardwood floor guy. The money she says he makes and charges is robbery in my opinion!! I mean I guess its market cost up there and going rate, but if they agree to pay I guess it does not matter.
But shes talking 2-3x what labor is in this area!!
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
PumpJack Brand Pump Jack (A55218)
PumpJack Brand...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
