Caroni replacement belts source?
/ Caroni replacement belts source? #1
redtruckfarm
Ridgefield, WA
Kuboat L3200
Currently running a Caroni TL1500 (Rear Flail Mower) and need to replace the belts. Any thoughts on where to find them? I've located the part number on AgriSupply but can't get a cross reference to any of the belts they supply.
/ Caroni replacement belts source? #2
I found belts at NAPA that work for my Caroni. I think the belt size is B43. About $15 per belt.
I went through a lot of belts until I learned to tension correctly and stopped leveling off gopher mounds with the flail.
Good luck.
/ Caroni replacement belts source? #3
Thanks for the tip. Any advice you can give on tensioning would be appreciated. The manual is pretty cryptic.
/ Caroni replacement belts source? #7
Good luck.
I just put new belts on for the first time -- using the recommended Gates B43 size. I have a Caroni 1900 which I purchased 15 months ago. The old belts were generating a lot of extra noise and I could begin to smell the hot rubber. They were completely frayed. How do I know the propper tension for the new ones? The nut on the tensioner spring was tightened nearly all the way -- and I never messed with it, so it was the factory setting. Thanks!
/ Caroni replacement belts source? #8
Trial and error was how I figured it out. Tight enough to avoid slipping under normal cutting loads, but loose enough to protect the PTO if you hit a a gopher or woodchuck mound.
I will try and get a picture posted later today where my tensioning spring is set at.
/ Caroni replacement belts source? #9
I keep spare Gates belts on the shelf for all my belt run mowers and usually find the best prices on EBay.
I have both the largest Caroni flail and estate finishing mowers and use them constantly.
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
Engine (A59228)
Engine (A59228)
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
