Mowing case 3206 mower
   / case 3206 mower #1
Anonymous Poster
Epic Contributor
I have a Case 3206 rotary mower that has had work done to the gearboxes on it. I used it another season and this season the rotary cutters spin fine until they engage some grass to cut. Then they just stop. The PTO is fine, the belts are turning to the gearbox input, and the shaft is turning into the gearbox. If you stop the tractor and rotate the cutters by hand, all appears to be connected, as the PTO shaft will be turned by this action. Does anyone have a shop manual and or parts book for the gearboxes for this machine?
   / case 3206 mower #2
Does your mower have a slip clutch? Probably near the gearbox,mounted to the pto shaft?
   / case 3206 mower
If it does, it would be internal to the gearbox. There is not an external slip clutch. The shaft into the gearbox is turning.
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
YANMAR VIO55-6A EXCAVATOR (A59823)
YANMAR VIO55-6A...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
19010 (A55851)
19010 (A55851)
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
