Case 446 engine info
/ Case 446 engine info #1
Dr Natedogg
74' Case 446
Anyone have advice for the 16hp onan??? Just wondering why it self idles up and down on it's own? Any help would be greatly appreciated!!!
/ Case 446 engine info #2
Most likely culprit is a leak in the intake manifold, but here is some more food for thought.
Lean fuel mixture ie leak in the intake manifold
Dirty carb
Dirty fuel filter
Defective fuel pump
Valve or Valve seat leaking
Gov. linkage not adjusted properly, worn, or binding.
Thanks Ken, I guess I have some investigating to do. The tractor was given to me for 3 weeks to see if I want to buy it. It came with the snowblower, the mower and a brand new push blade. He wants $1000 if I decide to keep it. Not sure what to do as I'm not that mechanically inclined.
/ Case 446 engine info #4
If you are not mechanically inclined, then perhaps you should give this tractor a pass and just buy yourself something brand new with a warranty from one of the local big-box stores.
Owning a used garden tractor that is at least 23 years old means that things are wearing out and will need replacement. It will be an ongoing ritual that will require an investment in tools as well as time on forums to learn how to address the problems. For some people, this is just not what they want to deal with and I think that you should be told this up-front.
For those who are into mechanical issues and are not afraid to get their hands dirty on a regular basis, the ownership of a Case GT can be very rewarding thanks to the abilities this tractor has over anything sold in HD, Lowe's, Ace or other places including Sears.
The replacement cost of the basic 446 is about $7,000.00 today with the deck. They are a high quality tractor and that's why it has lasted for all these years. If the Utility Blade is brand new and is an OEM blade, then the asking price for this tractor is quite reasonable, in spite of any minor issues it may have. However........ paying some shop to repair this tractor will get old and very expensive. Doing the work yourself is the only reasonable alternative.
Give this some serious thought before making the plunge.
Thanks for the honest advice but I want the tractor because : a) I really wanna learn about mechanics more and I wanna get my hands dirty and b) I want the 446 cause I had this exact same tractor when I was a kid. It was my first business. I loved that tractor and have many found memories on it. I'm just wondering if this engine issue of idling up and down by itself when in low idle is a deal breaker. The push blade is made by case stored inside with all the parts and never been used. The snow blower was used for one season before the gentleman passed away and never ran again. The mower deck has a missing center blade but other than that it's in pretty fair condition. Oh and it comes with tire chains too. I think the attachments alone should be worth the $1000 dollars but just a little hesitant if the engine is shot. It sat for 16 years in a shop and when I put a new battery and new fuel in it she fired with in 5 seconds of turning the key.
/ Case 446 engine info #6
Fun little tractors. My parents had one when I was growing up and my uncle bought a 444 also. Sure could push snow when we put chains on the rear tires. Noticeable difference between the two tractors when turning the rototiller. I think one pump was really warn compared to the other.
/ Case 446 engine info #7
My dads with the Oman also had overheating issues. He had a locol mechanic/body man cut out the top of the hood and replace it with a louvered section. That solved the heat issue and it was done well, looked factory.
Also when I took it for a spin to check all the gears (hi and lo) I noticed it sometimes won't switch between the two. Its hard to get it into hi when I'm in lo and then hard to go from lo to hi again. Really weird. No noticeable bend in the hydraulic gear bolt. Any advice???
/ Case 446 engine info #9
The toughness switching between high and low was common. Especially if there was any pressure on it. Try wiggling the forward/reverse lever as you are switching. I think this is what I uses to do
Yeah that's kinda what I was doing, so you think it's synonymous with these older tractors? I was thinking maybe the gears inside were not aligning properly. It takes a long time to get it back and forth through the high and low range. Like 5 minutes atleast of screwing around. The problem is that I know piss all about the hydraulic drive system or any system for that matter. I know a guy who has a 446 in good condition who parked it after the clutch went. He said it runs like a top and been stored inside since new. I could probably get a second parts tractor for about $400. Think I'd be crazy not too cause it comes with 2 attachments. **** he'd probably give it to me. Gonna go get it when I get time
/ Case 446 engine info #12
Wow. 5 minutes to shift. That is too long. Something is wrong or bent.
/ Case 446 engine info #13
Do this and you wont have a problem or even have to get off the tractor to shift between hi and low. Let me preface this by making sure that you understand that the tractor should be stoped to change between the two. If the lever will not move, that means that the gear teeth are hitting each other on the edges. Place the lever in nuetral and push forward on the travel lever and return it to the stoped position, then try to use the gear lever again. This should work in 1 or 2 attempts. Usually takes no more than 5 seconds to do this.
Here is a before and after pic of mine. Remember what you were told earlier, you will be required to actually work on this thing to make it work right, but there is alot of help to be found to help you along.
That's exactly what I did and it worked. Thanks for your help. I have a whole new problem and not sure if it's major. While engine is running I checked the oil and it's bubbling and spitting and I put my hand over the top and there's huge pressure??? Any thoughts??? Would that be an intake leak???
/ Case 446 engine info #15
I don't know why you would try and check the oil of a running engine because it is not possible to get an accurate reading.
Inside the crankcase, oil is flying everywhere, thanks to all of the components that are spinning. Crankcase pressure is also common. If you want to know the true health of your engine, then you need to conduct a leak-down test as well as wet and dry compression tests. The results of those tests will give you insight as to how much wear is on the engine parts and which engine parts (if any) are worn to the point of being a problem.
Rebuilding an Onan engine has never been inexpensive and today the cost has risen to well above the $1000.00 figure, depending on how much of the work is done by the tractor owner. That said, a competent engine builder/machinist should be employed to assess the block, do the machining necessary and then re-assemble the basic engine. Adding the heads, flywheel, sheet metal, starter, coil etc are all simple tasks along with putting the completed engine back into the frame.
I'm not saying that you need a rebuild. What I am saying is that you need to find someone to conduct the above tests to determine whether a rebuild is needed NOW or in the near future. Until those tests are made, it's anybodies guess whether the problems you are having are major or minor. A leaky intake manifold can cause all kinds of havoc and that is a common problem. Issues with the governor spring can also cause the "hunting" you describe.
Engine diagnosis is a step-by-step process and it begins with making sure that the valve lash is set correctly, the points and plugs are gapped to spec and that the carb is functioning as it should.
As for the gear changing issue from Hi to Lo range, just rock your body back and forth when sitting on the tractor and it will also rock. it only takes a couple of inches of movement to synchronize the gear teeth so that they mesh. Using the travel lever to do this is not always advisable because you run the risk of chipping the edges of the teeth. If that happens, the chips can get pulled into teeth of the Hi or Lo range gear and smash those gears when they reach the cluster gear.
/ Case 446 engine info #16
Not much chance of breaking a tooth off of the gear if its in neutral, but by all means, feel free to pull some muscle that you didnt even know existed by rocking around in the seat hard enough to move a tractor that in my case weighs well over 1000 pounds.
Thanks for the info hydriv. I have some work to do. My mechanic that I got a chance to talk to told me to check and see how much back pressure is coming from the oil dipstick. I didn't mean I was checking the oil (haha), I'm new to engine work but not that new. I now how to check the oil but thanks for making sure. I see how it sounded when I re-read it.
The engine just won't run smooth. I changed both spark plugs and it stopped "hunting" which I don't understand and now it just dies and smoke comes out the top of the carb when it does and it wreaks like gas. It's almost like it's flooding but still not running right while it runs. If that makes any sense. I'm gonna phone a mechanic and have him stop by my place. Any more suggestions would be appreciated
/ Case 446 engine info #18
I would check to see if this engine has a brass float or the composite float in the carb's float bowl. The composite ones have a tendency to swell with the crap they call gasoline today and then they rub on the sides of the float chamber.
/ Case 446 engine info #19
Ken,
When you switch from Lo range to Hi range, you are moving the cluster gear along the splined shaft that belongs to the drive motor. If you move the travel lever to make the motor spin, then you are also making the cluster gear spin. Trying to engage a spinning cluster gear into a stationary range gear does have the potential to cause tooth damage.
/ Case 446 engine info #20
Obviously i wasn't clear enough, moving the gear selector out of nuetral should only be done after the travel lever has been returned to the stop position. This is the way i do it and there is no gear grinding going on, if it was i wouldnt be doing it. I suppose if the travel valve were out of adjustment or damaged in some way that allowed the motor to still recieve oil when in the stopped position this could be a problem.
