Case 580E Backhoe
/ Case 580E Backhoe #1
BQZ
Case 580 E
Have a CASE 580 E Backhoe (model :Super E)that won't go forward ,got reverse no problem all the arms and buckets working fine just no forward
Here's what I've done so far :
1)checked linkage(seems to be ok).
2)check hydraulic fluid (full).
3)Drained fluid and replaced with new.
still won't go forward any ideas?
/ Case 580E Backhoe #2
There's a hydraulic shuttle valve located at the bottom of the linkage. If I remember correctly, upper right side of trans, remove floor pan to access. Probably your culprit and not too pricey either.
/ Case 580E Backhoe
I'll check it out
thanks for reply:)
/ Case 580E Backhoe #4
I know this might sound dumb, but my Dad was on my backhoe and he said the same thing. It just stoped on him and wouldn't go forward. I asked if it went in reverse, and he didn't know. He went and checked, and it didn't.
He said he didn't do anything to it, but it just stoped moving.
When I got out there, I looked for a hydraulic leak first, but didn't see anything. But I did notice that the drive shaft was off. It had sheered the bolts that attach it to the transmission.
Other then that, I don't have a clue.
Good luck,
Eddie
/ Case 580E Backhoe #5
Hi All we Do Case Genuine Spares with Doorstep Delivery Worldwide. Anyone in Need can reach us. We do Genuine, OEM, Aftermarket, New and Reman Both.
You can Reach us at
Home - Fluid Power System Technologies
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
2020 Peterbilt 337 S/A Dump Truck (A64556)
2020 Peterbilt 337...
