Case 75A Electrical Problems
/ Case 75A Electrical Problems #1
Tsugg
JD 4020, Case 385
Last summer I bought a new to me Case 75A in excellent condition. Everything worked except for one light, which I quickly fixed. It's the first time I have had a tractor that every light and everything else actually worked. I went out a few weeks ago to shred some grass and noticed a few problems. The headlights no longer came on. All the other lights worked fine. The tachometer did not work, it occasionally would bounce if you revved the engine really high. The batter charge indicator light was lit up on the dashboard. I found one wire under the hood that had been chewed through or broken. It looked like it went to the voltage regulator....maybe??? I repaired the wire and thought that might be it.....nope. I have traced all the wire bundles looking for some broken or chewed wires and I cannot find anything. I am about to get the trusty multi meter out and start tracking wires. I am thinking all three failures are somehow related since everything was working and this all happened at once. Has anyone had this happen? Any suggestions? Any help / pointers / advice would be greatly appreciated.
/ Case 75A Electrical Problems #2
Keep tracing the wiring. That is the only think I can think of. You may want to put some type of rodent precautions in the future. Good luck and keep us update. I have a T4.75. It is a good tractor like yours.
I started with 5 tractors and went through a buying and selling time trying to get it down to 2 good tractors, a small one and a medium one. Wound up coincidentally with a Case 385 and a Case 75A. I am very happy with both of them. The 75A is the first 4x4 I have had and I really like it.
I have put some rodent repellent packets in it. What do y'all recommend for rodent repellent.
CAT 988B Final Drive (A68134)
CAT 988B Final...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
More Info coming soon (A66738)
More Info coming...
TWO CHAINSAWS (A67714)
