Case CX31b Hydraulic thumb
   / Case CX31b Hydraulic thumb #1
Leot
I built a mechanical thumb for my machine but would like to convert it to hydraulic. The Case has "nibbler-breaker" hydraulic lines. I had a hydraulic cylinder I hooked up to test it and it does not retract I believe it is not a gravity return like on a snow plow since it has a return line but not sure. I am not really that familiar with hydraulics and need some help. What size cylinder "diameter" should I look for the thumb, the thumb is heavy duty and constructed out of 1/2-3/4 inch steel. I will have to figure out the length and maybe change the mounting brackets.
Also looking to get a quick attach bucket...any suggestions
   / Case CX31b Hydraulic thumb #2
The hydraulic breaker/hammer circuit will apply pressure to on port only and dump the other port straight to the tank. Or in order words, it's a single acting implement.
Somewhere in the machine, there should be a ball valve that you close, in order to convert the auxiliary lines to double acting. Meaning you can extend and retract a cylinder.
As far as cylinder size, I would go something close to the other cylinders on the machine.
Also, a workshop manual would be very handy to see if your auxiliary valve has work port relief valves. This allows the bucket to push the thumb away without breaking/bending stuff.
2007 BOMAG BW120AD SMOOTH DBL DRUM ROLLER (A52705)
2007 BOMAG BW120AD...
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
UNUSED FUTURE XGJ 40" MINI HYD TILLER (A54757)
UNUSED FUTURE XGJ...
UNUSED FUTURE FT36C STAND ON SKID STEER (A54756)
UNUSED FUTURE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
