Case IH 2294 Hydraulics Failure
   / Case IH 2294 Hydraulics Failure #1
wdoug
Case IH 2294
Case IH 2294 Farm Tractor - Problem is the tractor hydraulic rear remotes,
3-point lift, and clutch stopped working. Tractor does have power steering if you can finally get it in a gear and moving.
Would the hydraulic system charge pump cause this? I have oned this tractor about 4-years and looks like the main pump and charge pump have been replaced before my mistake of purchasing the tractor.
   / Case IH 2294 Hydraulics Failure #2
wdoug,
I've been studying on your problem for a couple days now and I think your problem lies in the charge pump drive.
The 2290, predecessor of the 2294 used to have a tendancy to either strip out the torque limiter disc on the flywheel or strip out the right angle drive that powers the main hydraulic pump and the charge pump.
If the torque limiter disc was slipping or the hub was spun out of it, there would be nothing to drive the pumps at all and since you say you have steering, I have to assume that the small gear pump that's piggy backed on the main hydraulic piston pump is turning. BTW, do you have brakes too? If you have steering, you should also have brakes.
The charge pump is driven by nothing more than a 7/8x 3/16 wwodruff key. Chances are, that key has sheared and the charge pump is not turning and not supplying oil to the main hydraulic pump.
There's usually a reason for a key that shears, they don't usually just snap on their own, so you should check that the charge pump isn't seized internally.
You can click here, then click on Hydraulics, then Charging Pump and Drive. The woodruff key is item #9.
I think .... and again, I'm not CERTAIN, but I think you can remove the charge pump and its drive without splitting the tractor.
Hope this helps.
Mark
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
