Cat 1 vs. Cat 2 3-point Question
   / Cat 1 vs. Cat 2 3-point Question #1
Dr G
Paso Robles, CA
none
Hello All,
My neighbor has a Kubota L3560. He has a ton of attachments, but does not live in the area permanently. Just visits on weekends once in a while. He's offered me the use of any of his attachments when I need them. I am reluctant to borrow someone else's tools, but it might come in handy here and there for some oddball thing.
I looked it up, and the website says that the L3560 has a Cat-1 3-point hitch.
The MX series that I am considering is listed as having both Cat-1 and Cat-2 (or maybe that means one or the other?).
If I do get an MX, would I be able to borrow Cat-1 attachments and use them?
Thank you in advance for any advice. Gustave
   / Cat 1 vs. Cat 2 3-point Question #2
Yes, there are bushings that you can use to convert the category 1 pins to fit the balls on category 2 arms. Tractor Supply Company or most any Ag supplier has them. The only possible issue I see is that you need to be careful not to damage the lighter weight equipment with a more powerful tractor. (Ask me how I know!).
   / Cat 1 vs. Cat 2 3-point Question #3
My 35 year old Ford is CAT I/II. The balls are interchangeable.
   / Cat 1 vs. Cat 2 3-point Question #4
We have a MX5800 and all of our attachments are either Cat 1 or compatible with both Cat 1 and Cat 2. Agreed about the bushings and that you need to be careful not to damage the Cat 1 attachments . Another thing to remember is that if you put a Cat 2 quick hitch on your MX, you will not be able to use the attachments that are only Cat 1 compatible. We just put a Cat 1 quick hitch on our MX and it works with all of our attachments except our ballast box, which we are regrettably replacing with a lighter ballast box that is Cat 1.
We really like our MX. If you have any specific questions about the MX, send me a PM and I will try to answer them.
Thank you gents.
By "balls", "bushings", are we referring to the spherical bearings at the ends of the 3-point links? To fit larger or smaller pins? Is that the only difference between Cat-1 and Cat-2, the diameter of the mounting pins? Or are the actual links of a Cat-2 more robust as well?
Some day this will all seem obvious to me, as it does you all of you now. But for the moment it's all new to me.
Thank you rbtjr for your offer.
Gustave
   / Cat 1 vs. Cat 2 3-point Question #6
Cat 1 uses approx 3/4" pins and cat 2 uses approx 1" pins. You can buy cheap bushings to "bush" cat 1 implements up to cat 2 size. You cannot make cat 2 pins smaller obviously. So you can pretty much run any cat 1 implement on a cat 2 machine with bushings but the opposite is not true for obvious reasons.
Cat 2 implement are generally much heavier duty and can handle much more HP. The spherical ends in the top link and lift arms are where you would insert the bushings.
   / Cat 1 vs. Cat 2 3-point Question #7
To further muddy the waters;
many of the tractors with dual sized 3 points actually have reversible lift arms.
If it's a 1-2 the tractor pins are cat 1 with cat 1 to 2 bushings on the tractor ends of the lift arms,
with cat balls on the implement end.
To use cat 2 implements the lift arms are reversed and the cat 1 ends are attached to the tractor and the cat 2 are available for the implement.
The larger tractors listed as cat 2 - 3 do the same thing.
Most people end up with the smaller ball on the tractor end and use bushings on the implement ends.
OK, I get it. This sounds like what in Motorsport are called "Rod End Sleeves". Allows one to insert a smaller diameter bolt through a rod end or spherical bearing than what the bearing was designed for.
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
