CAT 2 implement to CAT 1 tractor
   / CAT 2 implement to CAT 1 tractor #1
Gittyup
Elite Member
Mid Atlantic
Kioti CK25 Shuttle Shift, loaded tires, JD X739
Read through the few threads that talked about this trying to understand. But, after trying it, still confused. My CAT 1 top link pin just falls right through the holes in the CAT 2 implement. Read a thread about using 3/4" pipe on both sides of the toplink ball. But, how does this keep the top link pin from falling out? Can't find a "fat head" CAT toplink. Obviouisly, I'm confused.
   / CAT 2 implement to CAT 1 tractor #2
Depending on the pin, maybe washers at the outboard side, to keep it from falling out? Bushings to keep the pin from having too much slop might be a good idea.
One good thing about using cat II implements on a cat I tractor, is your not as likely to tear anything up, provided the tractor can stand the weight.
David from jax
I'm thinking about welding in a piece of pipe in the holes so that the implement is effectively CAT 1. Seems logical given that I'm using CAT 1 draw pins anyway.
   / CAT 2 implement to CAT 1 tractor #4
Definately need to use washers on each side.
I cut some sections of 1" pipe and welded into the holes today. Then ground them fairly smooth. I've ordered CAT1 draw pins with 1 1/8" threads. When they are installed it'll be a CAT1 implement. Still not there yet; need a longer top link pin.
   / CAT 2 implement to CAT 1 tractor #6
Just go to your local farm supply store and buy the bushings that will convert category 2 to category 1. TSC has them and they are specifically made to convert from 2 to 1. I bought some and some spares the last time I was at TSC.
I have a couple of the bushings. But, aren't they really to adapt a CAT2 3PH to a CAT1 implement? A floating bushing isn't going help keep my toplink pin in place. The spacing between the toplink support holes is 3 3/4". So, I'd need two just to fill the space. And I would still need a washer. I am trying to stay away from the washer option.
I suppose I could've welded in pieces of the bushings instead of pipe. I had the pipe and I thought it better to cut it down rather than a perfectly good bushing. Besides, I need the bushings to adapt the CAT2 top link I just got.
   / CAT 2 implement to CAT 1 tractor #8
"But, aren't they really to adapt a CAT2 3PH to a CAT1 implement?"
Yes you are correct, I simply misread your post! I will go sit in the corner for a time out now. Sorry!
No Problem. Appreciate the help anyway.
   / CAT 2 implement to CAT 1 tractor #10
Don't over-think this...Get a fender washer.. actually 2 of em.. one for the head side.. one for the lynch pin side... easy eh!
soundguy
UNUSED LANDHONOR SKID STEER UTILITY HITCH ADAPTER (A50460)
UNUSED LANDHONOR...
24ft x 28ft Metal Building (A48837)
24ft x 28ft Metal...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A48836)
1989 Chevrolet...
JCB 506-36 TELESCOPIC FORKLIFT (A50458)
JCB 506-36...
2024 Bobcat T650 Track Skid Steer (A47164)
2024 Bobcat T650...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
