corey9212
Platinum Member
Hello I was wandering if there is a bushing that will allow a category 1 attachment to attach to a category 3 tractor?
Thank you.
Thank you.
Not Cat 1 to 3 but Cat 1 6.5 foot disk behind my M135GX. Sometimes you just need to make do with what you have and my L5740 had something else. No, it doesn't come close to covering the tread width. Our JD7720 which has Cat 3 and sometimes gets stuck with the same little things.
Thank you, I will look into the bushings, all the attachments listed on my signature is what I will be using, the ones that can be upgraded are already upgraded to cat 2 pins but there are a couple that there is no pin and the part that would act as the pin is part of the actual frame (those are the ones I really have to figure out upgrading that's why I asked this question) it's good to know that I can't upgrade to cat 3 pins (at least not without drilling bigger holes). I will be very careful with the attachments I still plan on going the same speed that I'm going now with the lighter/smaller ones. The dealer didn't even realize the tractor was cat 3 until I pointed it out that the holes are bigger. He's confused cause the tractor that this one replaced (when they switched the number system to reference horsepower instead of the old system) was cat 2 so he assumed this one was cat 2 as well.
In fact the brochure says it is category 2 convertible to 1
5115M Utility Tractor 5M Series Utility Tractors JohnDeere.com
Might I inquire what is making you want to trade in??
