Category 2 Attachments
/ Category 2 Attachments #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
Why is it there seems to be very few implements/attachments for category two hitches? (75-100hp range) After looking at attachments for CUT's and SCUT's I noticed there are very few attachments for the larger utility tractors.
/ Category 2 Attachments #2
Most of the cat 2 stuff I have found has been at my local dealer, not on the internet.
/ Category 2 Attachments #3
Where are you looking? Plenty of stuff out there, but obviously there are going to be more Cat. 1 things available.
/ Category 2 Attachments #4
Depends on what ur looking for. Over half of the stuff i sell has cat 2 and im usually changing them to cat 1 for the customers.
I'm not looking for anything. I just noticed it when I was looking at attachments.
/ Category 2 Attachments #6
When I got the Cat 2 tractor the same thing was experienced. An ad was run on Craigslist in Northern CA for any Cat 2 implements for sale and there was not a single reply in three relistings. There is a lot of agriculture in the area.
Doing a search for Cat 2, Cat II, Category 2, etc. did not bring up anything.
I ended up changing the pins to Cat 2 or rebuilding the implement for use with Cat 2. Some of the equipment is used with Cat 2 bushings of course.
/ Category 2 Attachments #7
Generally the category 2 stuff is name brand equipment, and mostly oriented towards field work or other production type work, (and of course larger tractors.) Therefore, most short-line equipment companies don't carry it.
We have a Deere 3-bottom plow, 7' Gannon box blade, 8' Deere blade, large hay tedder, and a bale spear that are all category 2. Probably some other equipment that I'm forgetting as well...
/ Category 2 Attachments #8
A CAT 2 can handle CAT 1 stuff better than the other way around. :D
My new Bushhog brand 8' box blade came with one pin that is both CAT 1 and 2. That gives you 3 holes to align.
Thankful I got Pat's Cat 2 quick hitch it is a snap or click now. :D
/ Category 2 Attachments #9
The number of people using Cat 2 attachments is pretty small compared to the number of people using Cat 1 attachments, so they don't get advertised as much. The market for these is not as big, so they don't sell as many. It is similar to going to a car dealership and looking for a dual wheel diesel pickup. You won't find that many because only a few people will be looking to purchase them. However you will find alot of the economy car or the standard pickup. Another factor is that this bigger equipment is fairly expensive and when you spend that kind of money most people want to buy something that will last so they will spend a little more to get something of good quality. They also don't advertised as much on the internet, because most of this equipment can't be shipped to your house anyway.
/ Category 2 Attachments #10
Less money to build Cat1 and sell it at Tractor Supply, etc than to build Cat2 and sell it to people who might actually want an implement that is going to last behind a much larger tractor. I had a LOT of Cat1 implements that rapidly dimenished when I put them behind my Cat2 tractor. Ended up selling several of them to replace them with better equipment, rather than destroying them with the larger tractor.
David from jax
/ Category 2 Attachments #11
Yep, using bushings to make a cat I implement fit a cat II tractor is the first step in a potentially dangerous journey.
A cat II pto can turn a cat I implement into a pretzle, and the tractor will not even stall................
Thank gott in himmel fer shear pins........
and yeah, cat II stuff is expensive!
/ Category 2 Attachments #12
Most utility work is done by under 50 hp tractors on the farm and they are almost always cat 1. The bigger tractors will find matching tools with cat 2 on such things as Disc Mowers, 3 bottom plows, 2-3-4 shank subsoilers, chisel plows and 7 ft and larger rototillers, etc. These type implements are usually seen at the dealers in farming country. Dealers that specialize in CUT's and Sub CUT's have no need to have cat 2 implements on their lots. Ken Sweet
/ Category 2 Attachments #13
I thought Cat 2 was switched over aroung upper 30hp to mid 40 hp. I have a buddy that has a JD1020 tractor from the 60's and its cat 2. but he uses cat one implements. He really only uses a finish mower on it to cut his grass.
/ Category 2 Attachments #14
A little over dramatized, don't you think.
/ Category 2 Attachments #15
My buddy has been using cat 1 implements on his JD cat 2 tractor for years, now maybe its jsut cat 2 arms? but he has not twisted his tiller or bushhog or finish mower up yet. I think that is why they make sheer pins once the force is reached that the implement cant take the bolt snaps.
/ Category 2 Attachments #16
No, I do not. you of course, are not obligated to agree. Such disagreement does not nullify the damage I have personally observed when a cat II tractor overpowers a cat I attachment.
Do you shake a child's hand as if it were a full grown man? Proper "situational awareness" and attention the facts can make for harmonious operation.
I run cat I attachments on my cat II tractor, Also. Understanding that the tractor CAN overpower the attachment does not mean it has to. Only stupidity ensures that outcome.
/ Category 2 Attachments #17
This makes perfect sense for a flimsy 5ft box blade made for a 30 hp cat 1 tractor being pulled by a 75 hp AG tractor that it will just twist it up and pull the pins out, but how can a PTO twist up a bushhog when the shear pin breaks long before gearbox damage or damage to the structure should occur, just curious?
/ Category 2 Attachments #18
That was sort of my point. That's not what your original post stated.
/ Category 2 Attachments #19
Dad would say some guys could tear up a steel anvil with a small ballpeen hammer. Any equipment mangled is due to an accident or lack of care. I have broken and bent stuff not to the point that it was not repairable.
/ Category 2 Attachments #20
That old saying is around here too. However, it is with a "Rubber Hammer" :D Ken Sweet
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
78in Bucket Skid Steer Attachment (A61572)
78in Bucket Skid...
2017 International 4300 Box Truck (A62613)
2017 International...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
