CC fix for 60" belly mowers/decks
   / CC fix for 60" belly mowers/decks
Sorry, I was on the tractor cutting grass again, and remembered what else I like about the RFM. The RFM is rear discharge, and when you keep the RPM's up, it spreads the cut grass failry evenly behind you. I no longer have grass piles in rows where I just cut. It is nice, especially when you haven't cut grass in awhile.
As for my previous posts regarding the RFM everything else is pretty much the same. I did use it slightly differently today along the edge of my property where the weeds get about 3-4 foot high. I lifted it up about a foot, and knocked those weeds down a little in two 5' wide cuts. WOrked well. I could've done it similarly with the MMM, but it wouldn't have been able to have been raised as high.
For what it is worth.
   / CC fix for 60" belly mowers/decks #22
I have a Woods RFM for the Ford and a 60" belly mower on my Cub 5252. I've used the RFM a couple of times on the yard. It does a great job but I can't get close enough to the 20 or so trees and other obstacles in the 2+ acres I mow.
I use the RFM for another couple acres in the back of my property that has no trees, it works great there. If I wasn't so lazy, I could use the push mower for 1/2 hour and do the trimming in advance!
Curt
Curt
:D exactly:D
On a side note, do you find it easier to get around the trees when you go in reverse. I have only cut about 18 acres with it so far, so I am still getting the feel for it. To me it seems like a CC tank when you mow in reverse, except not nearly as slick.
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
2007 National RV Dolphin Motorhome (A51694)
2007 National RV...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
