ThomasH
If the ac force is not high freq, how could I outfit this machine to weld aluminum tig. And is there any way I could hook up a mig to it? Sorry for the insane amount of questions.
There are two types of welders, those which produce constant voltage (and the current will vary), and those that produce a constant current (and the voltage will vary).
MIG type welders are constant voltage machines, and your century welder is a constant current machine (assuming that I remember correctly) where you choose the output current and it tries to keep the current constant and varies the voltage.
These are as different as AC and DC welding, and unfortunately it means that your welder won't run a wire feed unit. There are aluminum spool guns made to add on to CV machines (MIG welders). So if you get a DC and AC MIG welder, you can hook up a aluminum spool gun and welding aluminum. The welder would need to be set in the AC position, and if equipped, the "cleaning action" adjusted by setting the % of the time that the pulse is negative.
The spool gun may sound like duplicating whatever is already there, but the thing is that aluminum wire is fairly difficult to "push" as it would need to do by feeding from the inside of the MIG welders through the cable to the handle. Spool guns have a spool on the handle, and therefore only have 6" or so that they have to push aluminum wire.
As you can tell, welding aluminum is a lot more expensive than welding steel, because it requires special gear that is not used in welding steel.
