CG2610 won't start, stater just spins
   / CG2610 won't start, stater just spins #11
Well, it's not the battery, not solenoid, not the ground strap...now for the bad news...the internal gear (made of nylon) that the planet gears engage from the starter motor. Not a great design as far as I'm concerened as it is the weak link and where all the torque is developed to engage the ring gear.
Well, the good news is this is the only occurrence of this I know of, on here.
Which means your the lucky one. Congratulations. :(
It seem I'm always special...but never in a good way. Found a starter out on the web but $452.29 plus shipping. OUCH!!!!! Found the internal gear for 17.78 plus shipping...anything else that anyone could suggest that should ne replaced at the same time? I'm leaning towards rebuilding it as it's not too old..
   / CG2610 won't start, stater just spins #13
If it is only going to cost $20 to put a gear in it, that certainly seems to be worth a try.
Please post the part numbers, and anything note worthy when your done. That way when Wacky's starter goes, he will know what to do. :thumbsup:
   / CG2610 won't start, stater just spins #14
Order a couple of gears. Be ready for next time.:D
   / CG2610 won't start, stater just spins #15
For now, can you nudge it past the bad spot and start it ?
   / CG2610 won't start, stater just spins #16
Any pics available?? :( I'm betting this may be a 2300 issue as well, down the road. (So far, so good, however....)
There is no dead spot, the nylon gear is missing teeth in three spots and the rest look mashed. Irving J...it apears that this starter is used on the GC2400 and 2600 series,and the newer 2300's but not totally sure from there. The Denso interchange number on it is 22800-8160. Waiting for a call back from the dealer's service department to see what they have to say. The first response was that it was a new one for them.
Here are a couple of shots of the gear damage.:mad: Thanks walt for setting me stright on how to post them....:D
   / CG2610 won't start, stater just spins #19
Ah! Now I see where the nylon gear is! I'll look in my GC book to see if it's the same set-up. Thanks for the photo!
Incidentally, I think that's precisely the same type of starter set-up (planetary gears with an outside ring gear) my '82 Virago 750 has, and they're famous for "blowing" starters. Sounds like a metal can full of marbles being shaken when I start it. So far, however, it still does the job- just sounds like ****!:laughing: My GC doesn't sound unusual, though....
According to the Agco parts web site the GC2300 family uses the same starter
2116FL (A56857)
2116FL (A56857)
1408 (A57192)
1408 (A57192)
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
