CHAIN DRAG HARROW
/ CHAIN DRAG HARROW #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I'm interested in chain drag harrow 6-7' wide by 8-10' long with support frame carried by 3-pt hitch. Any thoughts on how big a chain harrow you could carry with NH TC40 hitch.
/ CHAIN DRAG HARROW #2
you could probalby do an 8' wide one
But
I use a drag more than most people (business, need it for seeding, easily in the last month I've harrowed probably 100+ acres and I'll do 6 to 8 more tuesday) and I HATE the normal style ones. I've seen these and when the regular one I have now wears out (probably in a year or so), I'm buying one of these
slicker than snot, heavy, non-tangling, self-cleaning
really, very cool.
Hi-Valley Manufacturing
ok, their website needs help, but trust me, it's slick.
Tell them I sent you so they'll give me a discount when i need one.
/ CHAIN DRAG HARROW #3
The ones around here are sold by section, a section being 4' x 4' of 5/8" steel. To make your harrow wider/longer, you simply connect sections. Unless you have access to other types, that means you're looking at widths and lengths in 4 foot increments. I put together four sections in to make an 8' x 8' harrow, then framed it with steel pipe. I lift/transport it with an extended boom pole. Even though we're only talking 500# or so, lifting by boom pole shifts the center of gravity farther back. That could be an issue to tractors with light front ends.
There are ready made units with their own three point connections welded to what ordinarily is the tow bar. But since they cost as much or more as the chain sections myself, I made my own lift. So the answer to your question depends upon how many sections you hook together, and how far behind the tractor they get lifted.
//greg//
/ CHAIN DRAG HARROW
I'll need some sort of system to transport from field to field and need to cross a road and several short jeep trails. Since I don't weld, I'll probably have to buy commercially available carrier frame for 3-pt.
/ CHAIN DRAG HARROW #5
Just bought one on eBay with "buy it now", $350 delivered for a 6ft wide by 4ft long 120lb drag harrow. Came UPS about 6 days after payment. Interesting packing job for shipping.
Does what I wanted. Smooths the sand in the 60 ft ring I made for my wife to lung the horses. I'm clearing woods for the pasture. I wanted the harrow to follow the contours of the land rather then a box blade or your rake with a ridged edge. With a couple of logs for weight on top the drag is helping to smooth the contours well mixing in old hay, manure, and wood chips from the chipper. My MF 1540 could easily handle something bigger but this is the right size for my current needs to maneuver around trees and tree stumps still in the pasture.
When done I can load it in the bucket with just the pull bar hanging over on one end.
/ CHAIN DRAG HARROW #6
I just bought the 3-pt carrier attachment. It seemed ridiculously expensive at the time, but I really couldn't figure out how to do it myself so I bit the bullet.
/ CHAIN DRAG HARROW #7
Are there others still on ebay for sale??? Can you send a mfg name or link?
Thanks
/ CHAIN DRAG HARROW #8
This one is 8 x 8 feet and ran about 700 clams. I use it for a variety of things, arena groom, dethatcher, manure buster, seed bed prep in pastures, leveling... very handy device.
:cool:
/ CHAIN DRAG HARROW #9
There was a post here not long ago where a fellow had used a boom pole to raise and lower a homemade drag harrow. I'm going to try to duplicate that some time in the future.
/ CHAIN DRAG HARROW #10
I helped a buddy 'make' one using an old drag harrow and then welding some chain sections to some t-posts. thenattaching the chains tot he harrow.. seems like 9 short 6" chain sections were used to attach the t-post box to the 4x6 harrow.. then use a boom pole and attach up.. etc..
Looked 'improvised' for sure.. but all the parts were free.. so...
Soundguy
/ CHAIN DRAG HARROW #11
I looked at the ebay store before buying my 8x8 from a local dealer for $500 even. Ebay is not always a better deal. Apart from the super model that Lone Cowboy gave a link to (and which I wish I had noticed before ordering a conventional one), all chain harrows are basically the same, with some range of quality but not a very wide range.
/ CHAIN DRAG HARROW #12
I love my chain harrow. It is a "Maybridge" harrow I believe. 8'8" square and I drag it with a smaller tractor than you - Kubota L3400 with no problems at all.
I find that this size is perfect. Good size for doing the pastures and not too big for the arena.
/ CHAIN DRAG HARROW #13
I am trying to find something better than the one at this link, but have not yet. I may end up getting one to do some fall smoothing of 10 acres and clover planting of about 50 acres. I need something that will knock down old gopher mounds from many years, and this one looks heavy enough to do that even in grassy areas.
The fact that it is made within 120 miles of me is a plus also.
Anyone heard of these?
http://www.martensmfg.com/files/3point_brochure.pdf
/ CHAIN DRAG HARROW #14
Anybody else have any feedback on one of these?
3 Point
/ CHAIN DRAG HARROW #15
I ordered one last week and they finished it yesterday.
I should get it next week, and maybe try it out a few days after that. I'll post something then.
/ CHAIN DRAG HARROW #16
It's likely your 3pt can actually pick up more drag that you can easilly drag... etc..
soundguy
/ CHAIN DRAG HARROW #18
Just get some diamond harrows and be done with it. They will do just what you are looking for for results.:D :D :D
/ CHAIN DRAG HARROW #19
Please do. Much appreciated.
/ CHAIN DRAG HARROW
I bought the Wingfield 3-pt drag harrow in April. Has worked well to scour surface, loosen rocks, pulverize weeds, etc, for food plots. Added large truck tire to increase effect. Love it, especially for areas that have too many rocks for disc.
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
John Deere 3025E (A53317)
John Deere 3025E...
19010 (A55851)
19010 (A55851)
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
