Chain Harrow or Disk for Overseeding Grass
   / Chain Harrow or Disk for Overseeding Grass #11
CHARLZ is probably right; if you don't eliminate the competition first, you're probably wasting your money on seed.
   / Chain Harrow or Disk for Overseeding Grass #12
Most of the pasture grass probably is fescue and other common lawn grasses. If so, it would be a waste of time to kill it all and start over.
   / Chain Harrow or Disk for Overseeding Grass #13
If you recently built the house meaning the lawn area hasn't been routinely cut short then I would use the broadcast method. As mentioned cut it as close as you can and seed then water it. With regular mowing you might be suprized how much better that pasture grasss will look.
What do you use to mow the lawn? I use a spike tooth harrow to drag pastures with.
Gas Pump Artwork (A55758)
Gas Pump Artwork...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2008 Walker Diaphragm Pump (A55787)
2008 Walker...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
2013 BMW X5 xDrive50i AWD SUV (A55758)
2013 BMW X5...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
