Changed fuel injection pump oil and now Ford 1700 will only idle
   / Changed fuel injection pump oil and now Ford 1700 will only idle #31
AJ you don't need to remove the lines, just loosen the nut at the injector to bleed air. Do you have a drain or did you remove the back cover? Did you check the spring on the pump cover for correct install? Did you have gravity fuel flow?
   / Changed fuel injection pump oil and now Ford 1700 will only idle #32
No drain on mine, I had to remove the back cover. I made sure the spring is seated properly. I do have good fuel flow. I loosened the two nuts on the injectors on top of the fuel pump and have fuel flow through them. I have not taken one of the two off that are on top of the cylinder head to bleed it (don't know if it is needed). I thought I would take these two lines off (the metal, smaller lines) and blow them out--------I'm hoping there is trash in one and that's my problem. thank you for the quick response. I am trying to get smarter:). any other suggestions are welcome. I'm just frustrated because it was running fine before I changes the oil and fuel pump oil (could the oil change make a difference-----I would not think, but ?
   / Changed fuel injection pump oil and now Ford 1700 will only idle #33
Aj,
In think by draining the oil from back cover you might have moved the spring or caused something for the governor assembly not to work properly. I'd make sure governor is not binding in any form. That's what regulate flow of fuel and Engine speed at any given throttle position.
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #34
I'll look at the governor tonight/thur. and see if that's the problem. I am pretty sure I aligned the spring correctly on the pin that moves inside the pump when the throttle is activated. I think I have tried just about everything else. thank you!
   / Changed fuel injection pump oil and now Ford 1700 will only idle #35
Don't despair, It is eiither governor or you still have some air bubble in the injection line. Injection pump is a reciprocating positive displacement pump. the pump try to compress small amount of Liq (not compressible) thru the discharge line. if there is air bubble there it'll keep pulsating git back and forth without or very little fuel delivery. By the way did you adjust the throttle any? does it move freely all the way back and forth? what happens when you push the throttle high while the tractor is idling?
JC,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #36
You don't need to loosen the lines at the pump, that could introduce air in the line. Only loosen at the injector to bleed. I would not think you have trash in the lines if you have a good filter. Double check the spring on the cover is installed correctly.
   / Changed fuel injection pump oil and now Ford 1700 will only idle #37
ugh, I thought before I check the governor, I would make sure all air is out of "all" lines. I loosened the two nuts at the very top that connect to the pistons on the actual engine head (please forgive my terminology if it's wrong). while doing this the two pistons must have moved and created a foaming of gas at the base of them while trying to crank. With all the rust build up-------I got one off and cleaned and replaced, no leak now. the other is locked in and I can not turn it either way to tighten or loosen (have to get it off somehow). after I fix this "new" problem I will check the governor............I sure hope that is the problem. My spring is seated correctly. My hand throttle works properly, I can have it wide open or just barely past the "kill" position and same result. It will crank but just barely continue to turn over, like it is going to cut off at any moment. but it does not. the old saying keeps coming up................if it ain't broke, don't fix it:laughing: I bought it in great shape, doing the preventative maintenance was where I went wrong:confused2:
   / Changed fuel injection pump oil and now Ford 1700 will only idle #38
JC and jones6780,
I personally want to thank you both for helping me and giving suggestion. I took the "injectors" out (not pistons - you all are smart, I am not Ha/ha). I cleaned out all the gummed up diesel on the female threads on the head, got my injectors back in. I drained the fuel pump, again. I made sure the weights were working properly (they may have been hung up not sure, moved pretty good from what I could tell). Replaced my plate and this time I only added 1oz. of oil (I know this is not the recommended 2oz, but I wanted the see if I maybe was adding too much).
Last night I went back in the archives and read about 5 pages of conflicting theories of too much too little oil in the pump and too much making the engine not get up in the rpms. I fired her up and she like she was when I got her. I will probably go back and add a little more to the pump as I don't want to buy a new one (I have seen the prices quoted, ouch).
anyway thank you both for the help, very much appreciated. I also enjoyed reading all the past postings on "our" 1700s, good reading and good knowledge to have.
   / Changed fuel injection pump oil and now Ford 1700 will only idle #39
Cool Success as last:thumbsup: About the oil in the injector pump. Mine turned out to be exactly 2 oz. Again, there is a fill point on top, a drain hole and a level point. You can drain completely, close drain, open level hole and fill from top. as soon as oil about the escape from the level point you got enough oil. Now imagine old oil vs new cold, cold oil and warm oil. That effects, viscosity , pour ability (if there is a term like such, ha ha) and clinging effect. i had to take a air nozzle and shoot a bit air from the top and that afforded me getting another extra tea spoon of old oil. The oil the pump is moved by splashing and the governor weights do exactly that. I, for myself would not want to toast my high $$$ injector so want to have enough oil in there. Too much is bad as the oil expansion due to heat can certainly damage things.
JC,
JC and jones6780,
   / Changed fuel injection pump oil and now Ford 1700 will only idle #40
understood, I have one of those pumps without the level and drain screws in it. kinda hard to tell exactly how much to have in it, will add some more to be on the safe side (if it goes back to bad idle I can always take a little out). do you still recommend adding the "power service" additive to your fuel to account for the low sulfur content in today's diesel? I can't find off road diesel anywhere. I still need to replace coolant as well, I see many different recommendations, do you have a go to? I know you have had your 1700 for awhile. thanks
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
