Changed hydraulic filter now hydraulics don't work
   / Changed hydraulic filter now hydraulics don't work #1
terrymarine
Friendship
Deere
Fairly new owner of 2016 New Holland Workmaster 50. At 100 hours I changed the hydraulic filter. The filter was purchased from a NH dealer. I followed the owners manual directions. It did not say to fill the new filter prior to replacing it. After replacement the hydraulics, both loader and 3 point don't work. Can I bleed the system? I thought this would have been a simple job.......if you all have any advice for this ignorant but well meaning tractor owner I would sure appreciate it.
   / Changed hydraulic filter now hydraulics don't work #2
You probably have a filter plus full of air in there, can you put a vacuum (like a shop vac) on an orifice to prevent oil spillage then fill the filter?
I've had minor problems when changing a cylinder but they worked out.
/edit
You might want to try DLTTrekkers solution first.
Sir thanks for the quick response, I'll try it first thing in the morning.
   / Changed hydraulic filter now hydraulics don't work #4
loosen the thinner of the 2 hoses at your hydraulicpump....start your engine and when oil squerts out shut down and make sure o-ring is still in its groove ...then retightern hose.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2023 YAMAHA (A55758)
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2020 International MV607 Landscape Dump Truck (A55788)
2020 International...
1827 (A51248)
1827 (A51248)
