OP
jcummins
Veteran Member
- Joined
- Jan 14, 2007
- Messages
- 1,640
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
Well, the undisturbed bank at the end of the dam would certainly be more stable than the "fill" out in the middle of the dam. But you are going to change all of that when you dig thru it to lay the pipe. After that, it's all "fill" dirt right??
The design of a dam transfers the pressure from the water into the core of the dam. You aren't going to disturb that with method 2. You aren't installing a vertical pipe to the bottom of the dam core. You aren't even going to dig below the surface of the water at the water's edge. The pipe is going to be straight and lay at whatever angle gets it to dump in the ditch at the bottom. So the only place you are digging completely thru the dam "fill" is at the very bottom of the backside of the dam.
I just installed one last Fall on a smaller pond than yours. I placed it 3ft above the previous earth spillway level. Also added 6' of dam height. I used a 12" pipe because I left no earth spillway. Only drains about 20 acres. I don't expect it to ever go over.
Method 1 is going to have a trench on the back side of the dam...not deep and not into the core...to bury the down pipe...UNLESS I can use some type of open culvert. The total digging somewhere on the dam, is straight across and down the back side....I'm guessing it would be 120 ft or so of trenching....solely on the dam. Method 2 would cut 20 ft on an area that is at best a 1 ft high dam. The rest of the trenching would be completely off the dam.
I can see both ways, but method 2 seems safer...but more expensive. How much do you think it would cost to have someone put it in...method 1...method 2? I don't have a rear blade...but know where I could probably borrow a really heavy one....with TNT on my tractor, I've even though of digging a trench (method 2 only...not 1) and putting a pipe in that way.
I just went out and measured the freeboard at the very lowest point on the dam...which happens to be right in the middle....13". On average the dam freeboard is 16" or so. I have given thought of adding dirt to parts of that dam also.
