Charging battery in place?
   / Charging battery in place? #1
ackerrj
Kubota B2030
I am a relatively new owner of a 2320 ( this summer) with low hrs.
The tractor is garage kept, but we are in relatively low temp zone here in Colorado high plains, elev aprx. 5100 ft.
I have a new trickle and full charger from Sears... And use it to maintain battery at full charge in cold garage.
Any problem with charging in place on tractor, or is it best to disconnect one terminal?
Opinions or fact welcome!
Be well.
We are scheduled to be bellow zero next few days.
   / Charging battery in place? #2
Be well.
Charge in place is fine. However, the full charge and / or trickle can (chronically) ruin the battery if left on it continuously, even the trickle (unless it has a microchip processor for monitoring).
Consider this ==> Battery Tender Plus 12 Volt 1.25 Amp Battery Charger: BatteryMart.com
Also buy the 25' extension cord for it. ==> http://www.batterymart.com/p-12-volt-25-foot-extension-cable.html
I use these year-round, regardless of the temperature.
   / Charging battery in place? #3
Unless you are having issues starting in the cold weather I wouldn't bother. Cold weather is a way of life around here. As long as you don't drain your battery too much and leave it like that they will give years of service with no maintenance. However if it feels weak then can do damage to your starter. Think of it like a glass, when full it can't hold more water. You would be better off buying a block heater.
   / Charging battery in place? #4
I do not use a trickle charger on my Kubota, I only plug in the block/rad hose heater 1 hour before I need to use it. Somtimes it does not start up for 3 weeks when I am doing other jobs. In 17 years I am only on my 3rd battery and 2 of them were recon/ recharge from volvo's.
Craig Clayton
   / Charging battery in place? #5
:thumbsup: OP, listen to crbr. Continuous - even at a trickle will harm the battery in a few weeks and ruin it over a few months. Easy to lose track and youre screwed. Smart charger as mentioned, or a daylight activated timer that you can set for 1hr trickle per day.
larry
   / Charging battery in place? #6
crazyal said:
Unless you are having issues starting in the cold weather I wouldn't bother. Cold weather is a way of life around here. .
1+ on this reply. Don't fix a trouble that you don't have. I'd do block heater first. Spring is only seven weeks away.
Mike
   / Charging battery in place? #7
I keep my tractor in an unheated garage. Although it doesn't snow here as much as it probably does where you live I run the tractor at least once every two weeks pushing snow. This seems enough to keep the battery up. I have tried hooking the battery charger up but in a few minutes I get a "Full Charge" light. My battery is three years old. The charger I have has a microprocessor built in and isn't supposed to hurt the battery if left unattended. Even at that I won't leave it hooked after I get a "Full Charge" light. Save A Battery - All-In-One "Standard"
   / Charging battery in place? #8
I also think a block heater is a much better device than a battery charger. The block heater should screw into a tapped hole on the left hand side of the engine block, very easy install.
A 1 amp trickly charger will eventually boil a battery the size that your tractor has, not good for the battery. The only time I have used a charger on any of my tractors is when the battery in my first tractor was failing and I was trying to get a few more starts out of it. 13 years and only changed the battery once.
   / Charging battery in place? #9
Don't use a trickle charger. Use a float charger that charges only when needed. I keep one on both generators, my trailer, and my tractor. Batteries will last a long time (5+ years) using these. I have one that is over 10 years old. It was in my daughters truck for two years, but it was the wrong battery for that engine. I have had it on float charge for at least 8 years.
   / Charging battery in place? #10
Also buy the 25' extension cord for it. ==> 25 Foot Extension Cable: BatteryMart.com
What crbr said, but I like this little Deltran unit.
Battery Tender 12 Volt 800 mA Waterproof Battery Charger: BatteryMart.com
It can stand being out in the weather. My machines are parked under an open shed roof, and occasionally wind can blow rain in. It can also deal with AGM and sealed batteries, so very useful for the boat and for small sealed batteries. I've got 6 or 7 of these, and so far, so good.
Deltran is really clever about including both ring and clamp style terminations with an intermediate plug and cap. I permanently mount the ring type to my batteries and just unplug the intermediate plug when I want to run a machine. Very handy.
Whichever floats ( :laughing: ) your boat, but do use a smart charger.
Z.
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2019 JCB 457 (A60462)
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
