Parasitic load on battery
   / Parasitic load on battery #31
If you're still having isues, check the top of your battery for cleanliness. If the top of your battery is clean and depending on what part of the country your in, dust will conduct electricity. In some parts of the country, the dust/dirt will conduct more. Try putting your meter lead on the positive post and right in the middle of the top of the battery and see what the voltage is.
My guess is your battery, as you suspect is not up to snuff... One of those solar chargers can be a good investment, and just leave it on all the time.. I have one on the lawn mower.. all the time it is not mowing:).. seems to solve the problem.
Part of the challenge is that I have more than a few batteries around the house. Tractor. Lawn mower. Truck. Car. Motorcycle. The truck is the only one that sees regular use. Either I have to shuffle the charger between them or shell out $25 a pop for a trickle charger for each one. Whine, whine, whine...
   / Parasitic load on battery #33
Now that battery is up to "full charge" is the correct time to test it. If tested when run down, the conductence tester the dealer uses will tell them to recharge and retest. A conductence tester will aplly 50% of battery rated load for a specifice period of time then measure reserve capacity, if you have weak battery it will show up and tester will recommend replacing it.
Well, you think it's worth a call to them? I hate to end up paying $100 later, but I hate wasting their time too.
   / Parasitic load on battery #35
I would take the battery to them and have 'em check it. It will only take them about 10 seconds.
Well, ain't that a head-smacker. Why didn't I think of that?
   / Parasitic load on battery #37
Dunno if you are being sarcastic or not.....I can't really tell.
But nonetheless, if you have a 'dislodged plate' in the battery, it may reoccur during the trip to the dealer. Warranty will not be voided by removal of the battery. You won't need to pay the service call if the battery does test good. They will perform the test at no charge.
Sorry. I wasn't being sarcastic. I was sincere. :thumbsup:
Right. The head-smacker was that I hadn't thought to remove the battery and just take it in to be tested.
   / Parasitic load on battery #39
I have had a few newish battery’s replaced under warranty to the point I now feel guilty to take another one in my problem is my drive way is up a river bed every time we get heavy rain it gets strewn with boulders driving over them gives the battery a hard time shakes them to death in no time
   / Parasitic load on battery #40
That's why I mentioned a possible plate becoming dislodged. Most of the time, the dislodged plate will remain dislodged thus ruining the battery. But I have on 2 occasions seen where the plates will touch for a second, then not touch.............Makes it hard to diagnose.
Flameshield Safety Oil Tank (A59814)
Flameshield Safety...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
