Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
timely for this thread.
my mom called me at work this am with a dead battery in her 07 cady SRX
that's the one with the battery up by the windshield, and the alternator burried in the middle right front of the engine..
anyway.. I go over to her house. this happened previously about 2ys ago... battery was warrientied then.. but she got charged 150$ to install it ( ?? nice warranty gm..
anyway.. thus battery is 2ys old.
I get over there.. no lamps on.. nothing that should have made the battery die.. but yet it was stone dead.. 10v showing on my dvm.
anywho.. I had brought over a charger and let the bat charge up over lunch, came back and hooked up jumper cables to my diesel just to make sure there was no strain upon starting.
started up fine.
put one of those loaded 2 probe charge system analyzers on.. said bad alt. I let the car run 10 minutes just to make sure it wasn't reading a dip from the low battery / starting draw. tested again.. same deal.. low charge output. ( this is the metal kind with a nichrome? load resistor and a scale for testing bats and alts.. ).. put my dvm on and read.. car idling.. varried charge voltages from 13.2 to 13.45 had my mom rev it up and it actually dropped to 12.9 one time..
after 5 minutes of idleing and on and off again looking.. charge voltage never made it up over 13.45v.
since nominal bat voltage is 12.6, it -IS- charging.. but low...
I shut the car down and have now let it set a couple hours. bat shows good nominal volts and car started fine.. same low charge volts..
that's making me think alt is taking a dump.. and bat is good for now since it charged up and did not self discharge... also makes me thing there is not a heavy parasitic draw in the car killing it. gosh that alt looks like it is going to be fun to remove.. there is a tensioner on a ? 3 bolt bracket at the al mount, and then also a lower rad hose.. looks like it might come out the top with the lil plastic engine shroud slightly interfering.... yummy...
and here I thought the bat was hard to get to...
soundguy
started up fine.
soundguy
