Charging problem
   / Charging problem #1
timbertree
Bentleyville PA
John deere 318
I have a John Deere 318 garden tractor, that has a charging problem when mowing for about 15 min.
For some reason, the battery warning light comes on "about 15 min after I start mowing". If I turn the mower switch off, the battery warning light turns off.
My question is, where do I start? I know this battery is fully charged. So it's not the battery, and the PTO clutch is properly adjusted. I guess this leaves the rectifier? Does any body out there that messes with this type of stuff know what it is that's causing this problem? Or most likely know what the problem is.
Thank you
   / Charging problem #2
Don't know the answer but my Cub Cadet light stays ON for 15 mins after mower clutch engaged, then finally goes out. So I'm interested in the answer!
Jim
   / Charging problem #3
check charging voltage
   / Charging problem #5
   / Charging problem
I think it does, but not sure. I'll have to look into this again. But not today. thanks.
   / Charging problem
Murph, thanks for the information and help. For some reason it's working now. All I did was move the wires around, and pulled all three connectors on the rectifier, and cleaned all the spades up. Oh, by the way, the battery did drop down and level out like you said it would after running it for an hour.
   / Charging problem #8
What engine Model and # is in it? If its a Kohler, some have a dual system where the Electric clutch for the deck is run off
of 1 and the charging of the battery is a separate system.
   / Charging problem #9
Make sure your connections are clean and tight and your good to go.
2016 Freightliner Bucket Truck with Altec LR756 (A56438)
2016 Freightliner...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
17307 (A55853)
17307 (A55853)
