CHEAP BALLAST BOX??
   / CHEAP BALLAST BOX?? #11
I didn't use a toplink on mine either. I don't really go fast enough to need one. Occassionally the bbl will smack the swinging drawbar if I take off too fast, but its not a big problem. I'll have to get a pic of mine.
Timber said:
Hear is mine about 800 pounds with chain storage under the lid. I left about 10 inches of space near the top to put stuff. Just filled it with cement. Works great. Tucks in real close to the tractor too
   / CHEAP BALLAST BOX?? #12
I have never really had a problem with it at all. It rocks now and then but I prefer it to move. Sometimes when it bottoms out it just rocks instead of bottoming out the tractor. I use my box blade a lot too for Ballast but for Forklift work I always use the drum
   / CHEAP BALLAST BOX?? #13
flINTLOCK said:
I did a search and found many styles of BB's, homemade and storebought. I wondered what the cheapest workable solution might be? 55 gal drum filled with sand? Any good stories out there??
I've made weight drums for my loader tractors out of old feed tubs.. etc.. and some bolts / nuts and a drawbar.
These things usually cost me about 5$ plus the bags of concrete.
Soundguy
   / CHEAP BALLAST BOX?? #14
Thanks for some new suggestions of where to find barrels. I have some new leads now so I hope to find one locally!
   / CHEAP BALLAST BOX?? #15
Finally got some pics of mine.
   / CHEAP BALLAST BOX?? #16
I just bought two 55 gal plastic drums from Rural King (like TSC). They were $9.99 each - though I threaded fittings into the bungs and use them to water my trees.......... could fill one up with concrete for a balast
   / CHEAP BALLAST BOX?? #17
MD - Looks almost like you could use this as a roller as well.
   / CHEAP BALLAST BOX?? #18
I'm not sure how long the pipe would last it's only plastic. I figure it only weighs about 500 lbs. :D
   / CHEAP BALLAST BOX?? #19
Timber,
How is that rod holding up for your lower pins? Is it bending at all from the weight? I haven't decided whether to use a drawbar from TSC or a rod like you did.
   / CHEAP BALLAST BOX?? #20
That is NICE!!
Is that a piece of plastic culvert??
If so, what diameter?????
2021 Caterpillar 272D3XE Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
